Ecs P6STP-FN usb question
  • yonu
    • Nov 2007
    • 138
    ok on my Ecs P6STP-FN in device manager it list like a total of 5 usb ports however there are only 2 on the board and i can't find any open headers or places for them so my question is this how do I go about wiring in the additional ports? Also I am trying to stay away from using a hub due to space constraints where the system is going.
    Thanks,
    yonu
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Ecs P6STP-FN usb question
    You are stuck.
    You see them in device ma manger because the 'chips' for that many USB ports are built into the chipset but the manufacturer chose not to use them.
    When they do that the necessary wiring and other parts are not built into or installed onto the motherboard.
    Mann-Made Global Warming.
    - Dr Seuss
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Your best option is to get a POWERED hub.
      - One with an AC adapter.
      - Dr Seuss
      • yonu
        • Nov 2007
        • 138
        ok then perhaps my next question should be if they are built in to the chiset how would I go about tagging on to the pins at the chipset for those ports?
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          You would have to find the SIS tech docs for the chipset.
          I don't even know if they are published.
          - Dr Seuss
          • yonu
            • Nov 2007
            • 138
            ok thanks will start looking i assume then it would just be a matter of soldering on to the pins on the chip correct?
