Dell Precision 470 Workstation
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    #41
    Re: Dell Precision 470 Workstation
    Originally posted by PhatDude
    Main reason I want the SL8UD is so I can run Hyper-V or VMware or Windows 7 with XP Mode as it has the VT and XD bit.
    Damn that sucks... Guess I need to sell this machine and put the money towards a new one that supports VT...
    Microsoft has removed the requirement for hardware virtualization in Windows 7;
    http://www.techspot.com/news/38286-m...uirements.html
    • JEWilson
      • Sep 2007
      • 369
      • Scotland, United Kingdom
      #42
      Well guess what!
      I got a 670 complete from ebay for $60
      Listed as faulty.
      Sorry, I have no pics.
      When I rec'd it, I checked the caps straight away.
      Well, well, well same issue as found in the 470 vented caps in the CPU VRM.
      I will poly mod this in due course.
      Has anybody experience with poly modding these?
      I have a bunch of 820uF 2.5V Fujitsu FPCAP RE
      I suspect however some Pana FM 10mm (for endurance)
      will have to be used as well to get the total capacitance
      up to spec., certainly for the CPU VRM at least.
      I have checked the mobo for details of XC837/0XC837 in order
      to run SL8MA Paxville CPU but can only find;
      CN-0X0392-13740-479-0061 Rev A01 on the mobo
      I suspect this is not a compatible mobo.
      I will also have to check the PSU to see if it is ok
      Any help here appreciated
      • lazychris2000
        • Mar 2010
        • 20
        #43
        JEWilson, let me start off by saying that you got a great deal on that. I have a 670 I bought off a guy on craigslist for $100 (dual 2.8GHz narconas, 2gb, quadro 1300) that was shipped with 820uf polys in place of 2200uf electrolytes (all but 5 that is...just had to replace all 5 of the 2200s). Will have to check my voltage when i get to work tomorrow. I think theyre either 2.5v or 4v, tho. Can post pics tomorrow, too.
        • JEWilson
          • Sep 2007
          • 369
          #44
          Great
          That would be helpful
          Thx
          • TonyBerry
            • Apr 2010
            #45
            Got the mobo recapped now, took a long while
            Some massive ground planes leading away all the heat from the soldering iron!
            And, how may I ask, did you get around this? I tried my trusty 15/30watt iron first, then noticed the grounding plane, so I pulled out my big dog 150watt gun, but that didn't even phase it. Tonight, once I pick up a new tip, I'll try my Coldheat wand. Sometimes it can do stuff the conventional irons can't.
            I have 15-20 of these system to repair, so I'd like something fairly quick. I find it amazing that nearly all 31 of these capacitors managed to vent themselves. It seems like after a couple spewed, the system would die and the rest would remain intact.
            My systems are all identical: single 3.4Ghz Nocona, 2 x 512MB RAM, 250GB hard drive, DVD-RW, and DVD-ROM. Decent systems especially with the x16 PCI Express slot.
            I'm keeping 2 for myself and the rest are going cheap to pay for the capacitors and initial cost of the systems.
            Thanks!
            • 370forlife
              Large Marge
              • Aug 2008
              • 3112
              Don't use the ColdHeat! Thats a good way to destroy the motherboard in an instant.
              • JEWilson
                • Sep 2007
                • 369
                #47
                Y
                I found the same problem.
                I'm using a 50W Antec variable heat setting control dial.
                With some of the VRM caps, I had to exercise caution not
                to damage the pcb as I was using the iron at its full output.
                Even at this temp and power O/P, I had to keep the iron on the joint
                to get enough heat into it. Had to wet some of the joints also.
                Take your time, if it is not working, walk away and come back later.
                That is probably the best advice I can impart.
                In any event, with a number of well constructed pcbs from
                manufacturers, I am coming up against this problem recurrently.
                I am next, going to purchase a bench iron from a reputable manufacturer.
                Also, are these only 470s?
                I'm looking for 670s with the bad cap issue.
                HTH.
                • 370forlife
                  Large Marge
                  • Aug 2008
                  • 3112
                  Coldheat injects a high current into the joint to heat up the solder.
                  So essentially you could zap your VRM with the current from it.
                  • Per Hansson
                    • Jul 2005
                    • 5895
                    • Sweden
                    #49
                    TonyBerry; Welcome to Badcaps!
                    Yes, ColdHeat = Very bad idea, don't use it
                    To remove the caps with big ground planes like on this particular mobo just takes more time, but do you have prior experience recapping stuff?
                    It's not really different or anything from the normal stuff, we have quite good FAQ's on soldering instructions here on Badcaps; https://www.badcaps.net/forum/forumdisplay.php?f=24
                    The advise I can give is to use a good soldering iron, but don't overdo it, I use a 50w Weller temp controlled
                    As for the desoldering technique the most important thing is to add new solder to the joints, so you have an easier time melting and heating the solder that is already there...
                    JEWilson; the 470 and 670 use the same PCB, the only difference is that on the 470 not all PCI slots are populated and the SCSI is missing (as you can see in my pics)
                    So yea, the capacitor issue is exactly the same on the two systems
                    • TonyBerry
                      • Apr 2010
                      #50
                      Originally posted by JEWilson
                      Take your time, if it is not working, walk away and come back later. That is probably the best advice I can impart.
                      Thanks for the tip, but it wouldn't apply here. If I walk away, all the time I put into heating the ground plane is lost. I know, I know, just being literal.
                      Also, are these only 470s? I'm looking for 670s with the bad cap issue.
                      I only have 470's in my possession. As stated below, they are the same exact board minus the on-board SCSI and the last 2 slots. On the 470, the power supply takes the space that the last two slots occupy. You could easily use a 470 board in a 670 case.
                      • TonyBerry
                        • Apr 2010
                        #51
                        Thanks. Found it via Google (like I'm sure most have).
                        Dually noted.
                        Extensively. I've done dozens of the "pizza box" GX270 systems and I have done countless video game monitor chassis (Electrohome and Wells Gardner). Plus assorted projects here and there.
                        My iron and my gun are both Weller. The gun is ancient, but still works like a charm. I measured input wattage on both and it's as it should be. I tested heat level on each tip and it is also as it should be (assuming my pyrometer is working, which it seems to be as the back of my mouth is ~98*).
                        Anyway, back to the issue, would I get any benefit by somehow removing the old capacitors before attempting to desolder the leads? They are absorbing heat, so I would assume anything would help. I did try flowing fresh solder, but that didn't help. I tried 3 different boards and even different banks of capacitors. The smaller bank of 3 (just North of the floppy connector) doesn't have a huge ground plane, but I couldn't get those loose either.
                        • Per Hansson
                          • Jul 2005
                          • 5895
                          • Sweden
                          #52
                          IMO removing the capacitors would just make it harder
                          I just flip the board over, add some solder to the capacitor legs and then I heat them one by one and at the same time I just push the capacitor on the other side of the PCB with my other hand untill one leg goes out as far as it will, then I heat the other leg and so on...
                          With boards that don't have so large grounding planes I can heat both legs at once and the capacitor will come out almost by gravity itself...
                          • TonyBerry
                            • Apr 2010
                            #53
                            I decided this might be a good time to upgrade my "aging" Weller WES-51, so I purchased a Weller WESD-51. As expected, it really didn't do much better at removing these capacitors. It does seem to be getting more heat to the components though, because as I heat the backside of the board, the capacitor is getting so hot I can barely touch it to pull it out. I was able to get a good number of the capacitors on the areas without the massive ground plane, but no such luck on the "important" ones.
                            I'm considering something more aggressive at this point. If I could precision drill out the holes that the capacitor legs go through, I could save a lot of time and energy. I have also considered pulling the capacitor casings off and solder the replacement capacitors to the existing legs.
                            I've also thought about asking the local hobbyists who think they have some extreme soldering skills to do it for me. I'd offer them 50 cents a pop to remove a capacitor. They would jump at the chance to make "quick money", but they'd probably hate me (or refuse to do any more) after the first board.
                            • bigcape
                              Not new at it!
                              • Aug 2010
                              • 29
                              #54
                              Hey all,
                              I was sent over here to get some advice on "poly caps"?
                              This was my Exchange 2007 server that crashed, umm.. burned up day before yesterday.
                              She gave no warning just quit. I have taken them out (but y'all say these are top caps so.....?) with a HAKKO 808 desoldering kit. (darn thing works fantastic!
                              Here I was thinking I was going to pop into RadioShack, but I now see that is not going to work as hoped
                              sigpicThe master at blowing away MBR's and replacing Seagates!!!
                              • PCBONEZ
                                Grumpy Old Fart
                                • Aug 2005
                                • 10661
                                I hope you made a cap map taking note of the polarities in addition to uF and volts.
                                Excessive heat will kill any lytic after a while.
                                The ones that didn't bloat are probably aged pretty well and since you have them out anyway...
                                The photo is one that has been poly'ed.
                                Not sure if it's a newer revision or if its been rebuilt.
                                The Vcore caps can be down to 2.5v and 820uF is probably best.
                                The VRM-IN caps [caps on +12v that power the CPUs] need to be 16v caps and on a server I'd use at least 470uF.
                                The others you should probably leave as lytics at the original values because, without knowing exactly what they do or what actual voltage they are on, changing the uF or volts can much things up. [Little too late to check their voltages with a meter.]
                                Mann-Made Global Warming.
                                - Dr Seuss
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  When choosing replacement caps pay attention to old-vs-new diameters.
                                  That will bite you when they don't fit later on.
                                  And check your power supply too........
                                  - Dr Seuss
                                  • bigcape
                                    Not new at it!
                                    • Aug 2010
                                    • 29
                                    #57
                                    Originally posted by PCBONEZ
                                    I hope you made a cap map taking note of the polarities in addition to uF and volts..
                                    Oh yes i did and they are numbered on the board and polarity is clear
                                    The ones that didn't bloat are probably aged pretty well and since you have them out anyway....
                                    The ones that popped i had marked with a red sharpieI was not thinking I should pull all of them
                                    Not sure if it's a newer revision or if its been rebuilt..
                                    might just be my pen marks?
                                    The Vcore caps can be down to 2.5v and 820uF is probably best..
                                    All the ones I pulled were all 6.3v
                                    The VRM-IN caps [caps on +12v that power the CPUs] need to be 16v caps and on a server I'd use at least 470uF..
                                    Those are 16v 1000uF. you are suggesting change those?
                                    The others you should probably leave as lytics at the original values because, without knowing exactly what they do or what actual voltage they are on, changing the uF or volts can much things up. [Little too late to check their voltages with a meter.].
                                    There are four of the 6,3v that look in great shape. only thing is my range meter wont charge the board enough to get an accurate reading
                                    I took your photo and circled the ones that I pulled.
                                    If so many of them blew up how do you know if somethin much more fragile like a transistor/thyristor or a mofset isnt burned? They TO SMALL to see and toooo many of them!
                                    After all, caps can be used as voltage regulators. Oh and how can you tell the VRM-in caps from the rest of them?
                                    Sean
                                    • bigcape
                                      Not new at it!
                                      • Aug 2010
                                      • 29
                                      #58
                                      I hope this is not a thread jack..... but I am curious why you guys don't seem to like or talk about the 490 or 690.
                                      I have 4 690's and 5 490's They are awesome machines. One of mine has quad core E5465 xeons 2.8Gz. the 490's have X5160 3.0Gz all dual procs and are screemers!
                                      No offense but this is the only 470 I've had and in comparison it seems to be put together like Legos!
                                      • PCBONEZ
                                        Grumpy Old Fart
                                        • Aug 2005
                                        • 10661
                                        We repair broken things.
                                        We talk about what shows up here broken.
                                        - Dr Seuss
                                        • PCBONEZ
                                          Grumpy Old Fart
                                          • Aug 2005
                                          • 10661
                                          All of the caps you circled should be replaced with electrolytics.
                                          - Dr Seuss
                                            DELL MOBILE PRECISION 5560 CORE I7 11-11850H 16GB 512GB SSD 15.6IN W10 Mobile workstation Specification for Upgrade or Repair
                                            This specification for the DELL MOBILE PRECISION 5560 CORE I7 11-11850H 16GB 512GB SSD 15.6IN W10 Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the MOBILE PRECISION 5560 CORE I7 11-11850H 16GB 512GB SSD 15.6IN W10 boardview and MOBILE PRECISION 5560 CORE I7 11-11850H 16GB 512GB SSD 15.6IN W10 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request...
                                            09-07-2024, 02:20 AM
                                            DELL Precision 3520 Mobile workstation 3000 Specification for Upgrade or Repair
                                            This specification for the DELL Precision 3520 Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3520 boardview and 3520 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Precision...
                                            09-06-2024, 08:38 AM
                                            DELL Precision 3480 Mobile workstation 3000 Specification for Upgrade or Repair
                                            This specification for the DELL Precision 3480 Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3480 boardview and 3480 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Precision...
                                            09-07-2024, 07:19 AM
                                            DELL Precision 7780 Mobile workstation 7000 Specification for Upgrade or Repair
                                            This specification for the DELL Precision 7780 Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7780 boardview and 7780 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Precision...
