Abit SA6 successfully recapped
  • RuKK
    • Feb 2005
    • 34
    After getting a Abit SA6 with 18 bad jackcon caps on it for $10, I read everything I could here and last night recapped the board using free caps that I convinced jackcon to send me. This morning I fired up the board with a p3 667 and 128 of micron pc100.. Works beautifully at not only 133 fsb, but 175 Thanks guys, chances are I wouldnt have been able to do it without the information on this site and these forums. Hopefully this is the beginning of my recapping career!
    -RuKK
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Congratulations. its a great to see the board POST isnt it . Post some pics if you find time.
    • RuKK
      • Feb 2005
      • 34
      Just took some. And yes, thats my bed.
      And just because I can..
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16958
        Nice job!! I wouldn't have recapped with Junkcons, but thats just me.... Nice install, and welcome to the forums!!
        <--- Badcaps.net Founder
        Badcaps.net Services:
        Motherboard Repair Services
        http://folding.stanford.edu/
        Team : 49813
        Join in!!
        Team Stats
        • RuKK
          • Feb 2005
          • 34
          Thank you! Yeah I know, but they were free and I'm broke If they give me issues I'll replace them with rubycons or panasonics.
          • RuKK
            • Feb 2005
            • 34
            Oh before I forget, I've got a tip for you guys. I didnt have any flux, so to get the solder to flow onto the capacitor's leads, I made a paste out of baking soda and water and applied a tiny bit to the leads where I wanted the solder, then wiped most of it off with a cloth. Not quite as easy as real flux, but in a pinch it'll do.
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16958
              The off topic overclocking discussion was split and moved HERE.
              Team : 49813
              Join in!!
              Team Stats
              • Foetuss
                Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
                by Foetuss
                Hi all
                Hope this is in the correct place.
                I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
                Could use some double checking to see if I'm not doing something stupid .
                Pictures of the boards are attached.
                What I will be replacing with what : (planned)
                Soltek Golden ::
                4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
                6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
                01-18-2025, 11:44 AM
              • ziplock
                Abit BE6-II motherboard
                by ziplock
                Greetings,
                I have an Abit BE6-II motherboard that posts sporadically with the bare minimum components installed - CPU, RAM, PSU, and a Keyboard. I know it posts when the speaker beeps. Re-seating the components has no effect.
                I thought the sporadic posting might be capacitor related. Upon inspection, non of the caps are bulged or leaking and they are all original. So, I pulled them ALL. While the ESR is OK, over half of them are leaking current between 1 and 2 mA. The biggest offenders are way out of spec, like a 1500uf / 6.3V measuring 2600uF and many of the 820uF caps...
                04-20-2025, 02:09 PM
                ABit IP35 Pro Motherboard Schematic
                ABit IP35 ProABit IP35 Pro Motherboard Schematic
                A motherboard based on the Intel P35 Bearlake-P+ RAID chipset....
                10-31-2024, 02:06 PM
              • tbalint3
                Abit ST6-Raid repair
                by tbalint3
                Hello All,
                I am trying to repair an old Abit ST6-R motherboard.
                The symptoms are the following:
                I got it in a non-working state. I was told that it sometimes turned on, but many times just the CPU fan was spinning and no other signs of life, the board didn't POST, and now it doesn't POST at all.
                It was full of bulged electrolytic capacitors, so I replaced all of them with new Low-ESR ones, but it didn't solve the problem.
                If I install a CPU in the S370 socket, only the fans are spinning and no POST. There are no beep codes even if the RAM DIMMs...
                09-01-2024, 10:03 AM
              • N3Star
                Abit IC7 no POST 2nd battle
                by N3Star
                previously I gave up on this MoBo, but here we are again. For starters I'll give a link to previous thread: https://www.badcaps.net/forum/showthread.php?t=95433
                What has changed:
                - I still don't have a PCI GPU, but I have a PCI dignostic board
                - I measured the temperature and drain resistances of these hot MOSFETs:
                (right) 3.3V line: 100Ohms, gets up to ~80C,
                (left) 1.5V line: 430Ohms, gets up to ~65C
                What PC diagnostic says:
                -without GPU: goes through all post codes, keyboard is responsive, after hitting F1 key post codes go all...
                09-24-2022, 03:43 PM
