Razer mouse component.
  • diif
    • Feb 2014
    • 6978
    • England
    I have some faulty Razer Naga mice I am working on.
    They have different faults from not being detected by the PC to unknown device to everything working apart from movement.
    I am trying to identify the first component the 5v connects to.
    I'm hoping you can help.
    It's 6 pins, the middle on one side has the 5v in and on the other side the two outer legs show 3v, no other voltages to speak of.
    On a mouse that is not detected by the PC, I only get the 5v with nothing coming out.
    Apologies for the bad photo, but tricky using a £2 magnifier and the camera on my phone.
    It's marked ZE then has a 47 on it's side then a t.
    Thank you.
    • 30983
    Re: Razer mouse component.
    3v voltage regulator
    • diif
      • Feb 2014
      • 6978
      • England
      Cheers stj, any idea on the package ? it measures about 1.5mm x 3mm
      • fzabkar
        • Mar 2009
        • 772
        What is the full model/part number of the mouse?
        The markings suggest a NXP/Philips format, but I can't find an LDO regulator that matches the pinout. All I get is a dual transistor (PNP + NPN), but that doesn't seem to fit. I do agree that the part is most likely a 3.0V regulator. Which of the other pins are grounded?
          • 30983
          the package is just a SOT23-6
          nothing special.
          it may be a dual output regulator from ricoh
          • redwire
            • 3906
            Check any electrolytic capacitors, I've replaced many on Razer mice and it fixes the weird problems.
            • diif
              • Feb 2014
              • 6978
              • England
              Thanks guys, it's a Razer Naga 2014.
              The two pins with 3v on show continuity as do the pins on the other side at 0v.
              The Ground pin is opposite the 5v one.
              • fzabkar
                • Mar 2009
                • 772
                If the 3V pins are connected, then I would think that the part cannot be a dual regulator.
                It's interesting that the markings of both L3 and L1 have been removed in the full photo. It's also interesting that both parts are identified as Lx rather than Ux. The former is normally used for inductors but perhaps in this case it refers to LDO regulators. Can you identify the marking on L1? Is L1 an IC or an inductor?
                The microcontroller (LPC11U23F) is a 3.3V device (1.8V - 3.6V). If there is continuity between the 3V pins of L3 and the Vdd pins of the microcontroller, then this would confirm the function of L3.
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  Thank you fzabkar, I think it's just the poor lighting and photo that removed the marking from L3 in the big photo although L1 has no markings.
                  L1 looks to be an inductor, as I see little copper coils underneath the top.
                  I've tested the continuity between the 3v pins on L3 and the Vdd and the microcontroller and there isn't any.
                  • fzabkar
                    • Mar 2009
                    • 772
                    OK. I thought that maybe the markings on one mouse were erased, the other not.
                    Could U3 be the 3.3V LDO regulator for the micro? Could L3 connect to the optics?
                    I suspect that U1 may be a PSU supervisor which connects to the micro's reset pin. Its other pins would then be Vdd and Ground.
                    • diif
                      • Feb 2014
                      • 6978
                      • England
                      U3 is marked 3A2, two 5v inputs and a ground on one side with 3.3v on the other and a pin that's doesn't seem connected to anything. So yes that looks like a 3.3v LDO regulator something like a LP2980-N ?
                      U1 has 3.3v on two pins and also a ground.
                      L3 connects to the USB, ground and 5v in the middle and two sets of pins connecting to the Data+ and Data-
                      • fzabkar
                        • Mar 2009
                        • 772
                        I suspect that U1 might be something like this:
                        https://cdn.badcaps-static.com/pdfs/...4d9dac494c.pdf
                        https://cdn.badcaps-static.com/pdfs/...125ed7ee2a.pdf
                        FWIW, a marking code of M73 for the above part denotes a 3.06V threshold.
                        I wonder if L3 consists of the typical common mode inductor for the USB data lines plus additional components, eg ESD protection diodes? That said, what would be the function of L1?
                        • fzabkar
                          • Mar 2009
                          • 772
                          Could L3 look like this?
                          Code:
                                    +5V
                               common  -  - ESD
                                mode  ^  ^ diodes
                               inductor |  |
                                ___   |  |
                          Data+ o---UUU-----)---+--o Data+ (device)
                          (host)   ===   |  |
                                ___   |  |
                          Data- o---UUU-----+---)--o Data- (device)
                          (host)       |  |
                                    -  - ESD
                                    ^  ^ diodes
                                    GND
                          • diif
                            • Feb 2014
                            • 6978
                            • England
                            Thanks, L3 does look like that but the inductor is on the device side not the host side with a resistor and a cap then the inductor then connecting to USB_DM and USB_DP.
                            That looks about right for L1 although the pin arrangement is different.
                            • fzabkar
                              • Mar 2009
                              • 772
                              Other than checking for a break in the USB cable, ISTM that all you can do is to verify the 3.3V supply, MCU reset state, and 12MHz clock. If these are OK and the mouse is not detected, then I would suspect the micro.
                              If the mouse identifies via USB but doesn't move the cursor, then I would suspect the optical sensor, especially if there is no illumination of the surface.
                              • diif
                                • Feb 2014
                                • 6978
                                • England
                                Cheers for your input fzabkar, I have come to a similar conclusion although there is one mouse where the data+ and ground are shorted on L3. I'm waiting for a small hot air nozzle to arrive then I shall start swapping some components and hopefully get some out of these 6 mice fully working.
                                • fzabkar
                                  • Mar 2009
                                  • 772
                                  Try isolating/snipping the ground pin of L3. This should allow the Data+ line to float, but you will be without ESD protection on the ground side.
                                  • fzabkar
                                    • Mar 2009
                                    • 772
                                    XC6221A332, Torex, LDO regulator, 200mA, marking 3A2 = 3.3V:
                                    • diif
                                      • Feb 2014
                                      • 6978
                                      • England
                                      Thanks again.
                                      • Argirisarchi
                                        • Mar 2018
                                        • 8
                                        • Grecce
                                        did the mouse worked with this component?
                                        Thank you!
                                        I hope you are still member on BadCaps...
                                          Acer TravelMate P215-52-56G5+15.6" Bag&Mouse Notebook P2 Specification for Upgrade or Repair
                                          This specification for the Acer TravelMate P215-52-56G5+15.6" Bag&Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P215-52-56G5+15.6" Bag&Mouse boardview and P215-52-56G5+15.6" Bag&Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-06-2024, 07:20 PM
                                          Acer TravelMate P214-52-54NA+15.6" Bag&Mouse Notebook P2 Specification for Upgrade or Repair
                                          This specification for the Acer TravelMate P214-52-54NA+15.6" Bag&Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P214-52-54NA+15.6" Bag&Mouse boardview and P214-52-54NA+15.6" Bag&Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          Acer TravelMate P214-52-566U+15.6" Bag&Mouse Notebook P2 Specification for Upgrade or Repair
                                          This specification for the Acer TravelMate P214-52-566U+15.6" Bag&Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P214-52-566U+15.6" Bag&Mouse boardview and P214-52-566U+15.6" Bag&Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          HP ProBook 430 G7 + Elite Presenter Mouse Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 430 G7 + Elite Presenter Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + Elite Presenter Mouse boardview and 430 G7 + Elite Presenter Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-06-2024, 05:00 PM
                                          HP EliteBook 840 G6 + Elite Presenter Mouse Notebook 800 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook 840 G6 + Elite Presenter Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G6 + Elite Presenter Mouse boardview and 840 G6 + Elite Presenter Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
