Re: Recapping Asus PTGD1-LA
Just curious - is it a 4-pin fan or 3-pin?
Indeed. Not to mention how plentiful they are right now. You can buy them in buckets for just whatever they are worth as scrap - or at least the socket 775 ones. I just did a search on eBay, and it seems the price for the socket 478 CPUs has gone up quite a bit. About a year ago, you could grab s478 CPUs for less than $1 each if you were to buy a lot of 5 or more.
Yup, those are it (two of them did have normal profile brackets, though). The DMS-59 connector is annoying indeed if you don't have one. One time, I bought a video card lot on eBay only because it came with 3 DMS-59 to dual VGA adapters. Other than that, these video cards are not that noisy. At 13%, you *will* hear the fan with an open case, but barely anything when it is closed. That said, the newer drivers for these cards will throttle the clocks back. If you room is cool enough (under 68F) so that the card idles around 40C or lower, the fan might get turned off too. But if you were to place a larger fan (>80 mm) near yours and run it at 5V, it will make worlds of a difference and there will be no noise at all.
Good one!
Oh yes, MSI. I've never seen a hot VRM on any of their socket AM2 and older boards. Not sure about the newer ones, though. I'm not a fan of those gazillion-phase VRMs on new boards these days, though.
According to the P5GC-MX manual, no. But I did a bit of research online before to check CPU support (was trying to see if I can make the board run a modded s771 Xeon CPU), and both the 3.73 GHz P4 Extreme edition and Core 2 Extreme X6800 are supported. Also, all C2Ds are supported, but you can only run them at a maximum of 800 MHz FSB.
Sadly, not yet. Don't have any (good) cases left at the moment. I've also been meaning to finish recapping it for a while now, but I got short on good caps. Two of the 820 uF KZGs scattered on the board already bulged just sitting in storage, so I definitely want to get each and every one of them replaced (thus, I have to say it was a good riddance when you replaced the ones on your board).
I do something similar here with (usually) 120 mm fans. I don't mount the fan anywhere, though. Instead, I just let it sit at the bottom of the case and angle it about 45-80 degrees relative to the board. That way, air moves across the lower sections of the case in all sorts of bizarre patterns - which makes things run surprisingly cool.
Wait, did I really say 12?
I think my brain is definitely rotting. Should have been 7. I think the number 12 came from the price I paid for these video cards (about $2 per card, since I bought in a big lot).
Yeah, we hear ya!
It is not an overly-expensive card after all. And moreover, I understand that silence is golden sometimes. So I wouldn't sweat it either. But I think if you put a 80 mm or larger fan near the card (doesn't have to be blowing directly at it at all) and run it at a low speed, it will still make a mile of a difference.
Originally posted by Pentium4
View Post
View Post
View Post
View Post
View Post
View Post
View Post
