Resurrecting VP6 Unsuccessful
  • gchwala
    • Mar 2008
    I'm in a bit of a need in troubleshooting an unsuccessful recap. Being new to the forum and recapping I'm hopeful there was a detail I missed and that someone can help with.
    Here's the history: I've been running a VP6 with two 1.0GHz processors and 1 Gb Ram as a home server for about 3 years (not overclocked). The system had a Highpoint RocketRaid 454 card in addition to the onboard raid. I was running the OS (Windows SBS 2003 Enterprise) on 4x30Gb Maxtor harddrives in a Raid 10 configuration off the Highpoint RocketRaid card. I was running a raid stripe on 2x120Gb Segate drives on the onboard Highpoint 370 raid controller. All hardrives were solo (master) on each channel. I replicated many of the server features I was installing at work to test and experiment with (different hardware, same software configurations for exchange, domain controller, file server...). All worked well until Feb 08.
    After a wind storm passed through (not sure if that is relevant), I got a fatal error on the server (blue screen). Multiple harddrives had failed. I tried several reboots and never got past the windows splash screen before lock up, and could not recover any of the raid 10 drive failures (two drives had corrupted data). I decided to reinstall the OS. After booting from the CD, I could not get to the install/format of the raid array (4x30GB). The machine kept freezing. I looked at the MB and noted that 3 of 4 1000 caps were bulging at the top, and one was showing signs of leaking (brown junk coming from top). I tried to access the 2x120Gb harddrives in the bios screen and only 1 of 2 was reporting. Later determined that a board was blown on the second 120Gb drive (Lost all the data, family photos for past 7 years... this is another story about the wisdom of doing backups...). On my last attempt to reboot the pc. Nothing happened. No Bios, nothing (only red power led on VP6 was on). I suspected a bad power supply (Antec SL400 400Watt).
    Having found your FAQ's and Forum, I read feverishly for several days and ordered a recap kit. I finished the recap over the weekend and reconstructed the pc. I had tested the 4x30GB hds on a different machine and all accepted formatting and appeared fine. I checked the power supply with a different board and again all seemed fine. I did not have another machine to validate the CPU's or RAM. The red led is again lit on the VP6 MB but nothing else... Any suggestions before I relinquish this board as trash.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16956
    Re: Resurrecting VP6 Unsuccessful
    Recheck all your solder joints. remove te CMOS battery and close the clear CMOS jumper and let it sit a good 30 minutes. next power up, install only one CPU and one DIMM. If it worked before, it will work again unless you damaged it during the repair.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      open that power supply and inspect it too.
      oops now i see it is an antec.
      99.999% certain its loaded with fuhkkyu caps which have blown up.recap it too.
      if there were no burned coils or mosfets it should live.
      i still get a bunch of these in for recap and have a 99% save rate.
      i even sometimes fix ones with burnt parts if it didnt kill the northbridge.
      • gchwala
        • Mar 2008
        Thanks for your replies. TC, I'll give your suggestions a try this weekend as I will have a little more time then. I think I'll also take a look at the caps in the power supply then as well. I'll let you know how it goes (I've been spending the last several days working at a company making electronic timers and controls, and they have some sweet equipment for board repairs at their SMT machine and it makes me feel inadequate with the "hobbyist" equipment I'm using).
        • gchwala
          • Mar 2008
          Okay, it took me more than a week to get back to this, but the VP6 board is back!
          I'd like to close the loop on this thread. Here is what I did, I removed the board and inspected the solder joints, to my dismay, I found a few with suspect joints (I didn't think I sucked so bad at soldering). I reflowed all the cap joints and inspected again, all looked acceptable. I replaced the CMOS battery and this is when I noticed my error. I never set the CMOS Jumper back to the default setting last time, I just overlooked it several times. I reassembled the board to CPU et. al. and BAM up comes the BIOS screen. Thanks for the directions guys!
          • gchwala
            • Mar 2008
            Took a look around the forum for a link to TC's mod bios for the VP6, I'd like to give it a shot now that I have my board running again.
            Can anyone point me in the correct direction?
            Thanks!
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              Thanks!
              pm me your email that will take attachments and i will send it over.
              i use it here and it is known stable.
              • canadaboy25
                Drive SMART status not showing up through RAID controller?
                by canadaboy25
                Hey guys,
                I have an Asus M5A99FX Pro R2.0 motherboard with AMD RAIDXpert. I set up a 1000GB RAID1 array on it. This was about 8 years ago. Every once in a while, a power outage or something would knock one drive offline and degrade the array. After a reboot the drive would be back online and it would rebuild just fine.
                Recently, a drive dropped offline and the array became degraded. I figured it was no big deal and rebooted then set it to rebuild overnight. The next morning I took a look and both drives had dropped offline at 70% rebuild. Uh oh.
                I rebooted...
                09-24-2021, 01:56 PM
                Announcement: The Win-raid forums are closing
                by SMDFlea
                https://winraid.level1techs.com/t/wi...uncement/38021
                The win-raid forums are closing at the end of this year,its a sad time for all who have used the site to gain knowledge from some of the really talented members there.
                11-20-2021, 10:21 AM
              • bmxlovah
                Dell Precision T7910 no bios, no post after applying SAS/RAID setup
                by bmxlovah
                My Dell Precision T7910 died after enabling onboard SAS controller and applying RAID settings. There were no hardware changes between working and not working state, only setup (via bios -> controller settings). After applying settings and reboot PC turns on, flash leds (normally) but there's no further action, it just stays on with no graphics and no keyboard led's on. There's no Dell logo, nothing. I've tried resetting bios by jumper, replacing cpu's, replacing ram, removed/replaced cmos battery, disconnecting all drives etc. I've also dumped .bins from mobo chips SLI1 (16...
                11-24-2022, 06:29 AM
              • tbalint3
                Abit ST6-Raid repair
                by tbalint3
                Hello All,
                I am trying to repair an old Abit ST6-R motherboard.
                The symptoms are the following:
                I got it in a non-working state. I was told that it sometimes turned on, but many times just the CPU fan was spinning and no other signs of life, the board didn't POST, and now it doesn't POST at all.
                It was full of bulged electrolytic capacitors, so I replaced all of them with new Low-ESR ones, but it didn't solve the problem.
                If I install a CPU in the S370 socket, only the fans are spinning and no POST. There are no beep codes even if the RAM DIMMs...
                09-01-2024, 10:03 AM
              • canadaboy25
                Getting Windows to boot after changing SATA from RAID to AHCI
                by canadaboy25
                Hey guys I'm wondering if anyone has any ideas on how to get Windows 10 to boot up and install drivers after changing the bios settings for the sata port from raid to ahci.
                My motherboard is an Asus M5A99FX pro R2.0 and when I built the PC I set all of the sata ports to raid mode. There is one setting for ports 1-4 and one setting for port 5 and the esata port. I currently have 4 drives set up in two raid 1 arrays on ports 1-4. My ssd containing Windows 10 is plugged into port 5. I also have an external esata enclosure with a 2tb drive that I use as a Windows backup plugged into...
                12-02-2018, 02:17 PM
