HP ML110 G6 won't boot unless the CMOS is reset
  • seanc
    • Nov 2008
    • 1319
    I have a HP ML110 G6 that won't boot unless the CMOS battery is removed and re-inserted.
    The next warm reboot, power cycle or cold reboot, it will fail again.
    The beep codes it gives is 1-1-1-2 which seems to correspond to nothing.
    I've replaced the CMOS battery with a new one, just in case.
    Genuine HP memory has been tried, it makes no difference.
    The CPU has been swapped, it doesn't make a difference either.
    The above are verified working in that machine as when you can get it to POST, it will quite happily sit in the BIOS.
    I've managed to re-flash the BIOS and BMC with no luck.
    The Integrated Lights Out (BMC) always works and doesn't detect any issue with the hardware.
    There are only two electrolytic caps on the motherboard (Sanyo), the rest are poly caps.
    Does anyone have any thoughts?
    Sean.
  • Wester547
    • Nov 2011
    • 1268
    • USA.
    Re: HP ML110 G6 won't boot unless the CMOS is reset
    From research, this board does actually have Sanyo (Suncon) SMD electrolytics (some of which are easy to identify with the presence of a vent stamp) which may appear to be polymers. This may seem like a dumb question but does it work if you leave the CMOS battery out (which would reset CMOS upon each boot up, after you remove and reapply AC power) ?
    A bad chipset is a possibility. A SMD transistor critical for proper operation of the CMOS battery, around that area, could be bad as well.
    • claws77
      FX553VE-DM318T(FX553v) not POSTING
      by claws77
      Cpu i7-7700hq Ram - 8gb samsung, 32 gb sk hynix
      Gpu - nvidia geforce 1050ti
      Ssd orion o700
      Hdd hgst721010A9e630
      See images
      What's not working right?
      The system does not even POST, display is black,
      LEDs on - power led, aiplane mode, capslock fpr few seconds in the start(when connected to ac power) only.
      When did the problem happen?
      My laptop had dual boot setup, ubuntu and windows 10.
      It already had a moklist error, that would occur when i tried to boot ubuntu.
      05-17-2025, 04:09 PM
    • IamPritesh
      TPS 51125 only works after cmos Reset. HP 820 g1
      by IamPritesh
      Laptop will only start after cmos reset. TPS51125 does not generate 3/5 volt once you shutdown the system and try to turn it on again. Any pointers will be appreciated,
      Motherboard - 6050A2560501 - MB - A02
      01-23-2025, 03:05 AM
    • sheffieldyorky
      ZAB/ZAB A,B/ZYJA BLOCK DIAGRAM Acer Aspire
      by sheffieldyorky
      Hey there people
      While working on my Acer Aspire with the OS failing to load, I encountered a motherboard number of DA0ZHQMB6E 0 REV: E. I was getting nowhere fast or slow, for that matter.
      This is what I tried, but not in any order.
      Google
      YouTube
      BIOS
      Command Prompt (administrator privileges)
      On Google AND YouTube, I was getting mixed messages, try this and try that, but when you cross reference the advice it is either the wrong model (even though you enter the correct search term) a YouTube case in point, with the search term "how to...
      Yesterday, 02:22 AM
    • privato89
      Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
      by privato89
      I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
      Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
      Let's begin:
      Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
      03-26-2024, 06:37 AM
    • medinfo
      840 G4 if shutdown does not start until cmos reset
      by medinfo
      HP ELitebook 840 G4, if shutdown does not start, until cmos reset or with key WIN+B, when restart it start normaly but if shutdown does not start.
      - power button working
      - Bios updated to latest
      - CMOS Battery changed
      - Battery charged
      04-13-2023, 11:00 AM
