Hi guys need help here. Im repairing a dead unit from Asus, with model number P4S533-E. The BIOS is good I tested it with another working unit. No bloated Caps too. Visible non SMD Diodes are all ok. any suggestions?
Asus P4S533-E Dead Unit
Re: Asus P4S533-E Dead Unit
Originally posted by CompNeighNope. The battery is ok sir. Im testing them using a DVOM and LED's.
ZandraxHave an happy life.Comment
Originally posted by zandraxTry removing the battery for a few minutes: it should clear the cmos. Sometimes bad cmos settings prevent the bios from booting, I don't know why.
ZandraxComment
Originally posted by CompNeighI tried that sir. As I have said I tried the BIOS on another working board (Swapping) and it works fine. So the BIOS is out here. Im thinking of the Southbridge. I'm checking the PWR SW jumper now.
Excluding both bios and cmos settings, next troubleshooting steps are motherboard's integrity, power supply's quality and ram sticks:
- motherboard: does the led light when you connect the psu to mains? Are fans spinning when you try powering on the motherboard? If not, you are facing a lack of power good signal, due to an unreliable/faulty psu or to a motherboard damage (maybe the hardware monitor chip is broken);
- psu: write brand and model, because often an unreliable psu creates or exacerbates such problems;
- ram: low-end Asus boards are known to be quite picky about ram. Use only a stick and, if possible, try other ones.
Originally posted by zandraxBeware: the Power switch is not a jumper, is really a switch. A jumper will overheat, melting itself and [most of time] damaging the whole board, so never put a jumper on. You can power on the mainboard by closing the switch pins with a screwdriver for a couple of seconds.
Zandrax
worst case is it won even turn on.
most likely it will turn on,run 5 sec and turn off.
do you have a good dvm?
time to verify psu voltages,pg,vcore,vdimm,ect.
lots of things make a board not post.
common on asus are elite brand caps on vcore which fail without visible signs.
an 80h card may be of some help here too.Comment
Originally posted by kc8adui have never seen a case where putting a jumper on the powerbutton pin would melt anything.
I apologize for my mistake: I confused with them because of my memory.
I did put a jumper on the power pins when I tested an atx motherboard for firts time: the motherboard switched on and went off after about 5 seconds. I suddently remembered the 4 seconds forced shutdown, blamed myself for having done such a silliness and detached the psu from mains: the jumper I removed was quite hot, with a slight smell of burnt plastic. While it didn't melt, I feared it could have done: since then, I use only an insulated screwdriver.
Even though Im a newbie on this site it does not mean I am a newbie on repairs. ^_^
well anyway even before you posted your comments and suggestions I already did those. In fact those steps are sooo for starters. I did not use a jumper on the PWR SW I was refering to the connector of the PWR SW from the board side. this usually have 3V+. Yes I am using multiple VOM's Digital and analog. I have found the trouble. its a 3 legged IC near the front panel section. Its an SMD goshhh! If I'd replace this one I'd hope the board will be alright. If not I will assume its the South bridge that is defective.Comment
It may not be the south bridge...The super IO chip could be the culprit sometimes..coz fail to communicate with the bios chip ...i fixed few boards before..INTEL CORE2DUO E6600 LGA775 + Cooler Master Hyper L3
Asus P5W DH Deluxe (Wireless edition)
2Gb Kingston DDR2 800
Asus Xtreme N7600gs 256Mb Silencer PCI-E
80Gb WD 7200 SATA + 40Gb Maxtor 7200 x 2 +
80 Gb Seagate 3.5'' external HDD
HL-DT-ST DVD rom GDR8163B
HL-DT-ST DVD Ram GSA-4167B
20'' Dell FPM LCD
Cooler Master Centurion 5 + Acbel 450w with Active PFC
Philips A2.610 5.1 speaker +
Altec Lensing AHS30Comment
This specification for the ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year boardview and ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...09-07-2024, 02:50 AM
This specification for the ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD boardview and ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...09-07-2024, 02:50 AM
This specification for the ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB boardview and ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...09-07-2024, 02:50 AM
This specification for the ASUS ASUS E510MA-EJ015TS 15.6" FHD Intel Celeron N4020 Processor 4GB 64G with M365 1 year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E510MA-EJ015TS 15.6" FHD Intel Celeron N4020 Processor 4GB 64G with M365 1 year boardview and ASUS E510MA-EJ015TS 15.6" FHD Intel Celeron N4020 Processor 4GB 64G with M365 1 year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated...09-07-2024, 01:30 AM
This specification for the ASUS ROG ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD boardview and ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated...09-07-2024, 01:00 AM
- Loading...
