HP dc7800p Date and time Problem
  • sassan
    • Apr 2014
    • 79
    • France
    i have two hp dc7800p,with the same problem,time and date and bios setting keeps resetting ,i updated the bios and changed the cmos battery and still the same problem everytime the machine is unplugged.
    any ideas?
    Thank You.
  • TechGeek
    Computer Geek
    • Jan 2015
    • 2254
    Re: HP dc7800p Date and time Problem
    Check the terminals running from the battery holder to the motherboard. Also, is there an oscillator for the time/date timekeeping? If so, check those terminals and resolder the CMOS battery's terminals and resolder the oscillator's terminals and report back on the status.
    Permanently Retired Systems:
    Kooky and Kool Systems
    sigpic
    • LatinMcG
      • Jun 2015
      • 73
      • USA/Puerto Rico
      lol reminds me one time in 2001 asus a7ava or something .. we used jumper of reset cmos with power on.. smoke came out of a diode near batt and lost date also like this.
      • george_gpu
        kydos k32nh22cd date time problem
        by george_gpu
        hi,
        i dont know if it is same as lg ,the time in this tv goes 1980
        do you know if has battery in mainboard ?
        can anyone send me firmware ?
        08-19-2022, 10:42 AM
      • pkslowk
        Debug Card Error Code and Solution
        by pkslowk
        Sr. Motherboard Debug Error Code Solution
        1 Intel 845 E9 Bios Related Problem
        2 Intel 845 D4 CPU Socket Related problem
        3 Intel 845 37 Bios Related Problem
        4 Intel 845 7C Bios Related Problem
        5 Intel 945GCPE 34 Bios Related Problem
        6 Gigabyte 845 2 Ram Related Problem
        7 IBM Server A6 A7 Ram Mismatch Problem
        8 Asus 845 29 CPU Related Problem
        9 Lenovo I946 97 C-Mos Jumper related
        10 Gigabyte 845 A0 CPU Related Problem
        11 Asrock G31M-VS D7 Bios Related Problem
        12 Compaq 845 BD-70G B0 CPU Socket Related problem...
        01-28-2021, 12:51 PM
      • dj-bobr
        Thinkpad W541 (20EG) Q1, weird behavior after SPI flashing (3 flashes of power button LED)
        by dj-bobr
        I kindly ask for help with Thinkpad BIOS/ME repair.
        Thinkpad W541 board bought from Aliexpress, so I have no service tag nor S/N. It is 1GB version Q1 (K1100 nVidia GPU). BIOS 2.23, EC 1.13, ME 9.1.32.1002.
        It worked fine until I tried to remove whitelist.
        Steps taken:
        - battery out, CMOS coin cell out, laptop disassembled; I kept LAN/USB subboard connected
        - i took SPI programmer (CH341A with 3.3V mod) and SOIC clip and did a full backup of all SPI flash chips (SPI1 and SPI2 - BIOS, EC, ME, GbE; SPI3 - video BIOS; SPI4 - Thunderbolt fw) for several...
        03-05-2024, 04:28 AM
      • flat-earther
        Adding a clock battery to action camera to retain date&time when changing batteries Campark X25
        by flat-earther
        I have a cheap action camera with an annoying trait, every time I change batteries the date & time gets reset and I have to set it again.
        To solve this problem I want to add a small internal battery inside it which will keep supplying power to the camera for a while while I change batteries so the date & time is retained.
        I have opened the camera and I think there is enough room to add something inside to accomplish this:
        The camera is powered by a 3.7V nominal single cell lithium ion battery.
        So I need to connect another battery in...
        06-08-2025, 02:00 AM
      • insomniacno1
        Thinkpad L540, won't turn on unless I switch ram
        by insomniacno1
        This is a very weird problem and super annoying, so if someone who has experience with this, can explain why this is happening, then I will be grateful😁
        This happen usually when the laptop has been moved. from one room to another OFF charger for some hours, but has also happened when laptop has been shut down and left ON charger over night, and not moved :
        I turn on the laptop normally by pressing the power button briefly, then power comes on and Power LED and Fn LED turn ON/OFF constantly (no post and no beep codes)
        If I(and this is my only option at this point),...
        09-29-2025, 05:58 AM
