Asus M2N68 & M2N68 PLUS
    Hello
    I have 2 motherboards , Asus M2N68 & Asus M2N68 PLUS.
    Both board running OK, BUT only whit old card on PCI slot.
    If I boot whit old PCI card , i can install SO, make other tests etc ... all is OK
    If i mount PCI Express video card, no boot, just beeps.
    I try :
    - different PCI Express video cards (nVidia & ATI)
    - bios update (whit old PCI card)
    - other RAM, power source
    Both motherboard have problem whit PCI Express slot.
    Please give some solution.
    Re: Asus M2N68 & M2N68 PLUS
    Tried setting the BIOS to boot using the PCI-E VGA card? There should be an option in the BIOS named "Primary graphics adapter". Check if that option is set to PCI-E VGA or PCI-E.
    Main rig:
    Gigabyte B75M-D3H
    Core i5-3470 3.60GHz
    16GB DDR3-1600
    Samsung SH-224AB DVD-RW
    Delux MG760 case
      Already tried...
        Those boards of yours have the nForce 630a/GeForce 7025 chipset. There you have your problem. Reflow the Northbridge and the PCI-E will work again... for a few months that is.
        Only heat up the die in the center of the chip and not the whole package, as this issue has nothing to do with the solder balls, the chip itself is defective. Needless to say, it is absolutely not worth replacing.
        A working TV? How boring!
          I will try reflow ... tomorrow
            3 time reflow ... same result
            L.E.
            I rise up temp , reflow again, motherboard boot OK whit PCI Express card
              Just reflow and second board. Again, boot OK whit vga PCI Express card.
              Reflow at 430 C , 30 sec
              Thanks for help
                Maybe with good cooling those chipsets will survive?I've seen people put some big heatsinks and fans on nVidia chipset boards (anything over nF4) so maybe it helps cooling down the chipset?
                Main rig:
                Gigabyte B75M-D3H
                16GB DDR3-1600
                Delux MG760 case
                  On a desktop motherboard you have better chances of keeping them alive, indeed. If the nForce chipset is kept under 60C there are good chances of it running fine for 1 year or more.
                    I owned this particular model before (M2N68), in my opinion, Asus is using low quality pcie slot or faulty component maybe. I was using a Geforce GT210 at first, after few attempt of changing cpu case, which require me to remove the graphics card for a few time, then it started to not detecting my cards. I have tried a lot of cards with this motherboard, 9600GT (i have 3 of it), X1300XT, HD2400XT and all of it won't detect and give display. But the miracle was, it will detect my MSI 7600GS no matter what, even if I plug in the card half way, it still can detect it and give display, my guess was the 7600GS pcie connector was slightly thicker than others, because when I slotting in the card i can felt more tightness than other.
                    And btw, this board is very picky with ram as well, with my 7600gs in, it won't give me display if i was using Kingmax ram.
                      nvidia.....again
