Epox EP-8K3A+ Mobo
  • JEWilson
    • Sep 2007
    • 369
    • Scotland, United Kingdom
    Epox EP-8K3A+ Mobo
    Hi
    I am having a problem with this board and rec'd it as dead.
    The board will power up but issues an alarm as with a memory
    error. Further investigations found the first memory slot to
    be faulty and I removed this (with a great deal of difficulty)
    with a view to installing a better (molex) ram slot than the
    cheapo that was formerly there.
    Unfortunately, I have noticed a number of what I believe to
    bypass caps on the RAM slot are missing. These are;
    CB127 and CB225
    As I do not know the values of these, for the purpose of
    replacing same, can somebody supply the device values
    if possible?
    Any help, greatly appreciated - thx
  • bgavin
    • Jan 2007
    • 1355
    Re: Epox EP-8K3A+ Mobo
    I have four Epox 8K7A boards that all show memory errors, such as C1. They are all fixed by recapping the board.
    • JEWilson
      • Sep 2007
      • 369
      Thanks for responding
      I will do that with all the electrolytics as a matter of course.
      All the electrolytics are made by GSC and are coloured green.
      Are these known to be bad caps?
      Can you help with the values of the very small SMT capacitors
      I have referred to further?
      Thanks again
      • proxneo
        Recapping Sony ICF-SW55 - verifying cap values
        by proxneo
        Dear reader
        I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
        At the moment, I have selected replacements based on the following list of values:
        3 x 470uF 10VDC
        3 x 4.7uF 35VDC
        4 x 47uF 50VDC
        8 x 22uF 6.3 VDC
        1 x 220uF 6.3VDC
        5 x 100uF 6.3VDC
        Which...
        06-21-2023, 12:38 AM
      • rashidjafar
        Nvidia GTS 250M Laptop graphics - Inductor and Capacitor values
        by rashidjafar
        I am looking for capacitor & Inductor values for my TOSHIBA Qosmio X500-110 - mobile graphics - Nvidia GTS 250M Laptop.
        Values for :-
        PC43 : Capacitor [3x1.5mm]
        PL7 : Inductor [2x1mm]
        PC39 : Capacitor [1x0.5mm]
        Any ideas would be appreciated.
        I can get Capacitor values from nearby components but wanted to know the max ratings also I dont have equipment to measure inductors....
        08-07-2025, 05:10 PM
      • Kobok
        Different (lower) resistor values on PCB?
        by Kobok
        Dear Alls,
        For sure it id a stupid question, but help me to understand. I am in a Dell 2007WFP revitalizing project - searching reason why not starting. Some resistors needed to replaced is is obvious. When I have soldered some resistors the measured (with multimeter) values were sometimes rather different written on them. I supposed these are wrong units so I desoldered and made a checking measurement and voilá the values is the same is written on. This happens only in case of a few resistors, most have the same values (+/- 10%) are written on it. "strange" SMD resistors =>103...
        09-19-2022, 07:30 AM
      • ChaosLegionnaire
        by ChaosLegionnaire
        09-13-2022, 09:02 AM
      • DeXXter
        HP VICTUS 16-d0500la Some Values
        by DeXXter
        Here some measurements on HP Victus 16-d0500la, it might help someone, the values are on diode mode->mV and some lower ones on Resistance->Ω.
        This specific laptop has an Intel i5 11400h + RTX 3050TI, the values are from a working laptop....
        03-13-2025, 03:16 AM
