ga-6vxd7 nos with bad hermei caps
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    got this as an old stock dust catcher cheap at a local mom and pop store.
    as i opened the bag for the first time an odor appeared.
    you guessed it.
    leaking caps.
    oily crap around the base of each of the hermei 330@25v
    all the others are sanyo.
    its all recapped now and works fine.
    goes to show you dont have to use crap caps for them to fail.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    You have any pics of those?? Iwill was notorious for using Hermei caps... I've never seen them vent, but I have ran into flaky boards with these caps. Upon further analysis of the caps with my Sencore LC102, they were far out of any useable tolerance.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      they are probably long gone.had several pickle buckets and cat litter containers full but they started to stink and the containers were more usefull for sorting tubes so they got dumped.
      iirc they were black/copper and had a honeycomb sort of vent.
      the capanalyser 88 showed them to be open.
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16959
        Yup, the Hermei's are the ones with the goofy honeycomb vent, I do remember that...
        Team : 49813
        Join in!!
        Team Stats
          by momaka
          03-12-2025, 03:42 PM
        • eryjus
          by eryjus
          05-10-2023, 11:21 AM
        • Paxman_Swede
          by Paxman_Swede
          Hello!
          01-14-2025, 09:51 AM
        • captain150
          by captain150
          03-16-2025, 07:34 PM
        • Foetuss
          Gigabyte GA-6OXT :: caps question
          by Foetuss
          Good evening
          I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
          Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
          But I was also suprised about the bigger boys, which are 330µF 25V.
          Could it be they used 25V caps because they were cheaper / available at that time?...
          02-11-2025, 12:22 PM
