GPU - AMD Radeon RX 6600 MECH 2X 8G missing voltage
  • thebarber
    • Nov 2022
    • 12
    • France
    I have an RX 6600 from MSI, and it has no power. I have found no shorts, and almost all voltages are missing:
    • I have 5V on the back of the card (U310), but it seems to be used for video output (5V_VESA).
    • All fuses seem okay.
    • The thermal camera shows no hot spots.
    • I have flashed the latest BIOS (using CH341A). It makes 1.8v and 0.75v come back
    I am used to repairing shorted cards and replacing blown components, but here I am stuck.
    For schematics and board view, I use the Rev 2.0 PDF schematic, as nothing is available for Rev 1.0. However, Rev 2.0 is not the same; components are not located in the same places.
    rx6600 front r/GPURepair - MSI rx 6000 (xt?) ms-v502 rev 1.0: no power
    I think the issue might be with L500, which has only 0.378V instead of 5V. I'm not sure if the GS9230 can step down the 5V (it seems okay). Or maybe the components which give the 5v to this L500
    I didn't write other coils values because there were @ 0v.
    I have for gs9320:
    - pin 22 (VIN): 12v
    - pin 2 (EN): 1.8v
    - pin 10, 11, 16, 17 (LX (out?)): 0.3v
    - pin 21 (VCC): 0v !!
    I tried to replace it but same value, i remove the coil (L500) and it is the left pad u/0.3v and not the one connect to the gs9320, I was thinking that U501 is feeding the L500...
  • FriedFred
    • May 2024
    • 140
    Is there a connection from Pin 21 to the VCC power rail?
      AMD Radeon RX 6600 XT (RX6600XT) Schematic & Board View
      The Radeon RX 6600 XT is a performance-segment gaming graphics card by AMD, launched on July 30th, 2021. Built on the 7 nm process, and based on the Navi 23 graphics processor, in its Navi 23 XT variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on Radeon RX 6600 XT. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The Navi 23 graphics processor is an average sized chip with a die area...
      10-01-2024, 12:10 PM
      AMD Radeon R9 290 / R9 380 / R9 390 Schematic & Board View
      The Radeon R9 290 was a high-end graphics card by AMD, launched on November 5th, 2013. Built on the 28 nm process, and based on the Hawaii graphics processor, in its Hawaii PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon R9 290. The Hawaii graphics processor is a large chip with a die area of 438 mm² and 6,200 million transistors. Unlike the fully unlocked Radeon R9 290X, which uses the same GPU but has all 2816 shaders enabled, AMD has disabled some shading units on the Radeon R9 290 to reach the...
      10-01-2024, 12:46 PM
      AMD Radeon RX Vega 56 / RX Vega 64 Schematic & Board View
      The Radeon RX Vega 56 is a high-end graphics card by AMD, launched on August 14th, 2017. Built on the 14 nm process, and based on the Vega 10 graphics processor, in its Vega 10 XL variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX Vega 56. The Vega 10 graphics processor is a large chip with a die area of 495 mm² and 12,500 million transistors. Unlike the fully unlocked Radeon RX Vega 64, which uses the same GPU but has all 4096 shaders enabled, AMD has disabled some shading...
      10-01-2024, 01:07 PM
      AMD Radeon RX 470 / RX 580 Schematic & Board View
      The Radeon RX 470 is a mid-range graphics card by AMD, launched on August 4th, 2016. Built on the 14 nm process, and based on the Ellesmere graphics processor, in its Polaris 10 PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX 470. The Ellesmere graphics processor is an average sized chip with a die area of 232 mm² and 5,700 million transistors. Unlike the fully unlocked Radeon RX 480, which uses the same GPU but has all 2304 shaders enabled, AMD has disabled some shading units...
      10-01-2024, 12:52 PM
      Thermal pad thickness for various laptop GPU / Graphics Cards
      ASUS Dual RTX 2070 OC 8GB
      ASUS ROG STRIX RTX 3080 OC
      ASUS ROG STRIX RTX 3090
      ASUS TUF Gaming RTX 3080 OC Edition
      ASUS TUF GTX 1660 S-O6G GAMING
      EVGA RTX 3060 Ti XC GAMING 8GB
      EVGA RTX 3060 XC GAMING 12GB GDDR6
      EVGA RTX 3080 FTW3 ULTRA GAMING
      EVGA RTX 3080 TI FTW3 ULTRA GAMING
      EVGA RTX 3090 XC3 ULTRA GAMING 24GB
      Gainward RTX 2080 Phoenix GS Specs
      Gainward RTX 3070 Phoenix 8GB
      Gainward RTX 3080 Ti Phoenix
      GIGABYTE AORUS RTX 3080 MASTER 10G
      02-09-2024, 08:08 AM
