MSI V381 REV 4.1 VDDCI_MEM LOW RESISTANCE
  • jermac0711
    • Jun 2022
    • 74
    • Philippines
    Guys I need some advice with this GPU..
    All voltages is present except on vddci_mem
    enable signal is present< pwrgood is present in U704 but no output voltage going to L705.
    RESISTANCE : DIODE MODE 0.0022
  • dota1990
    • May 2017
    • 20
    • Philippines
    what is l705 resistance?>
    • Nagy Daniel
      Lowest possible resistance on laptop motherboard rail - Guide Table request
      by Nagy Daniel
      Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
      I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
      I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
      So, I generated a table with AI so I can...
      03-04-2025, 08:24 AM
    • rex98
      JS47A/JS57A/JS77A NM-E531 onboard ram disable
      by rex98
      hi i have this laptop IdeaPad 3 15ABA7 this is the boardview https://www.badcaps.net/forum/troubl...90#post3740490
      nm-e531 i tried all kinds of bios editing and it doesn't work. it doesn't have schematic but it has boardview with board ID details in it.
      maybe you could help me how to shift these resistors to disable its onboard ram.
      this is is the presents and not presents...
      10-07-2025, 03:39 AM
    • cind12
      GTX 1080 TI Gigabyte Aorus low resistance on vmem
      by cind12
      Hi guys, i was wondering, i've got 9Ohms on Vmem, one of the mosfet was shortet to ground, so i've desoldered hi and low mosfets nad still low res, then i removed all of the memory chips, and the resistance is still low, so did you had maybe a card with that low res on memories, and the card was working fine ?
      Removed the U1866Q and still without result, i dont have thermal cam so can't see where is hot spot when incjeting voltage.
      The resistance on core is ok 0.1Ohm ((Power 0.8V when on)
      Resistance on 12V 4K ohms (Power present when on)
      Resistance on 12V PEX 4K ohms...
      12-08-2023, 09:09 AM
    • ResoluteHawk
      Lenovo Legion S7 15ACH6 Not Posting
      by ResoluteHawk
      I have a customer that brought in a Lenovo Legion S7 15ACH6. The problem is that the laptop is not posting.
      My first thought was to take out the DRAM and put it back in.
      No POST.
      Then I swapped the dedicated RAM with good known working RAM.
      No change.
      I then measured to see if 1.2V was being generated for the memory to turn on, so I measured PL600 which is where the output of the 1.2V rail is.
      Resistance was good; measuring ~40Ohms with the slotted RAM in.
      I took the slotted memory out and measured again.
      Resistance with...
      12-02-2024, 10:17 AM
    • novice1
      Acer Aspire E5-574G - Not Powering On
      by novice1
      Laptop name Acer Aspire E5-574G. Processor = i7-6500u. GPU = NVIDIA GEFORCE 940M. Motherboard Model = DA0ZRWMB6G0
      This laptop was not powering on at all so I started investigating. The blue light would come on for a second, and then disappear. Fan would sometimes turn on for a second and then shut off immediately, and at other times would not turn on at all.
      To start with, about 3 months ago I had no clue about soldering, motherboard schematics, board view, and then I stumbled about this forum and other stuff online. I have never done any of those before. But to ask...
      11-03-2023, 05:53 PM
