Lenovo G31T-LM2 Not posting
  • s_henya
    • Jan 2011
    • 483
    • Israel
    Hey,
    i always wanted to get in deeper
    about desktop boards repairs besides easy fixes as blown caps or FETs
    i used to throw many 775 boards that refused to post.
    So, this board was attempted to be fixed by a previous tech,
    4 caps already has been replaced 470uf/16v
    tested the board with good known cpu ram and psu.
    the board powers up but no display on the onboard vga, or external pcie card.
    i can hear a little attempt to beep but thats it, cpu fan working.
    any ideas what else to test, or just give up on this one ( i have 3 more boards that wont post, and i really need a spare board, used my last one a month ago)
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Re: Lenovo G31T-LM2 Not posting
    The first thing I see wrong is bent pins on the yellow IDE connector on the board. I think two are touching - get those straightened out.
    Next, check the CR2032 CMOS battery. Some motherboards will not boot if it's weak or dead. I just had this happen on an Intel motherboard like 3 days ago.
    Use only one RAM stick, and preferably something old and highly compatible, such as 256 MB or 512 MB.
    There seem to be some brown Chemicon caps on the motherboard. Not sure what series they are, but if KZG, then a good starting point would be to replace all KZG caps.
    Finally, check the standard voltages on the motherboard with a multimeter:
    CPU V_core (voltage depends on the CPU)
    CPU Vtt (1.1-1.2V for LGA775, if I remember correctly)
    RAM Vdd (1.8V)
    RAM standby (1.2V, I think)
    Northbridge Vcc (probably 1.5V to 1.6V)
    Southbridge Vcc (always on, usually 3.3V)
    Using this picture as a referene:
    https://www.badcaps.net/forum/attach...6&d=1408540657
    CPU V_core is located under the group of those small caps with red stripes around the CPU socket.
    CPU Vtt is the Source pin of that lone MOSFET next to a lone brown (KZG?) cap, right by the CPU 4-pin 12V connector.
    RAM Vdd is connected to the left side of the toroidal inductor, under the red IDE connector.
    RAM standby should be connected to a bunch of small 4-way array SMD resistors between the RAM slots.
    Northbridge Vcc is connected to the toroidal inductor under the PCI-E slot.
    Southbridge Vcc is likely connected to that single cap between the Southbridge and RAM slots.
    • s_henya
      • Jan 2011
      • 483
      • Israel
      I am sorry but i could not finish the tests and update.
      My client decided not to fix it.
      i had to return it back.
      Sorry...
      • kalimuthu
        • Jul 2012
        • 19
        • india
        Try to update bios
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
        • howardc64
          by howardc64
          07-24-2025, 05:17 PM
        • DynaxSC
          Stubborn GIGABYTE B365M AORUS ELITE - main PCIe x16 GPU port working only in x8 width mode
          by DynaxSC
          I have this board, where I have exchanged the LGA1151 socket. During testing I discovered, that the large PCIEX16 slot won't by no force work in x16 mode, but keeps to work in x8 mode only.
          I tested this with GPU-Z, also with Render Test (but tried also Furmark and Heaven Benchmark - no effect).
          Tested on Core i5-9600K as well as on an Pentium G5420 and MSI NVIDIA GTX1070 and 2 other cards, including RTX3060Ti.
          Board architecture definitely allows x16 mode, as all 16 PCIe lanes are present between CPU and main GPU slot (nearest to CPU).
          05-04-2025, 12:08 PM
        • Habble7
          Lenovo ThinkVision P40w-20 no power – ILPI-422 VA board repair help
          by Habble7
          I'm trying to repair the power supply board from a Lenovo ThinkVision P40w-20 monitor. The board is labeled with the following markings:
          - Main PCB code: ILPI-422 VA (dated 2021/11/24)
          The monitor is completely dead, no power LED or backlight. Upon inspection, I found a few components that appear damaged, particularly some resistors that are burned and unreadable.
          Attached is a high-resolution photo of the power supply board.
          Does anyone have a schematic, boardview, or similar power supply that can help identify the...
          05-15-2025, 02:38 AM
