DELL P2219H Not turning on
  • INH
    • Oct 2023
    • The Netherlands
    I have a DELL P2219H which does not turn on, the light does not come on for the power button, I would like to know what voltages are supposed to come out of the power supply board so that I know if the board is ok, then go forward to the mainboard. The board number is in the attachment.
  • INH
    • Oct 2023
    • The Netherlands
    This is the board number
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • master3112
      by master3112
      07-29-2025, 01:55 PM
    • Garret Matt.
      DELL Latitude 5430 Rugged CORE_D5K Rev.A00 Schematic and/or Board View
      by Garret Matt.
      I'm Working on replacing an Inductor on this Dell's board and I need to come up with a compatible replacement. As much as I would like to smash a comparable 2R2 in the same spot I'd like to confirm the specs before confirming a killed board. For my purposes I'd be happy with a second opinion on the replacement inductor or the actual schematics/board view. As this is a commonly used Dell Rugged in my local service area, schematics would greatly help in the future.
      Thank you in advance for any assistance you can render.
      Inductor In question. Buzzes like...
      06-20-2025, 01:21 PM
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
