HP Elitedesk 800 G1 SFF power up, no bios, no logo
  • axeba
    • Feb 2025
    • 4
    • Italia
    The PC (an i7-4770) first took about 30 seconds to show the logo, then I updated the bios from DOS to the latest version 2.71. It did the update and when I restarted it died. The light on the motherboard is green, and the power button is fixed white, no beep, if I try to press the button again the PC turns off normally. I also tried to reprogram the bios using the CH341A programmer, but it does the same thing.
    should it end up in the landfill?​
  • iulik17d
    Intel Arc A380 videocard power limit remove - BIOS needed
    by iulik17d
    Hello everyone!
    The Asrock A380 low profile card (ID 8086 56A5 - 1849 6006) have an power limit of 45W. Intel removed the possibility to increase power using the software utility, anyway the card is in an proxmox machine that doesn't run windows.
    The same hardware is in another form by the name Asrock A380 Challenger that have the same VRMs and the power limit is at 60W. I searched online and found on another website an .bin bios file from the Challenger variant, that I flashed using an CH341a. Flashng worked well, I put the card in PC and booted. GPUz shows that new device ID is 8086...
    01-10-2025, 02:33 PM
  • PantherDave
    by PantherDave
    Hi all!
    05-29-2024, 02:01 PM
  • mrrubik
    HP Elitedesk 800 G6 mini - No power/no beeps
    by mrrubik
    I have a very strange issue with a HP Elitedesk 800 G6 mini (35W) unit - I acquired it as a barebones unit (no CPU/RAM/SSD), when plugging in power without any of this, I receive the correct 3 long, 5 short beeps (CPU initialization error).
    I acquired the correct CPU for this, an i5-10500T and 8GB of RAM, after installing it into the motherboard:
    1. Plugging in power adapter does not trigger auto-initialize (quick fan spin/power on check), the AMBER LED below motherboard does blink to indicate power connected
    2. Pressing power button does not turn unit on, the white
    08-23-2025, 09:22 AM
  • throwaway327
    by throwaway327
    Model No: RC72LA
    Serial No: SBNVKD001014459
    06-18-2025, 05:52 PM
