NVIDIA GeForce GTX 1660 Schematic & Board View
The GeForce GTX 1660 is a performance-segment graphics card by NVIDIA, launched on March 14th, 2019. Built on the 12 nm process, and based on the TU116 graphics processor, in its TU116-300-A1 variant, the card supports DirectX 12. This ensures that all modern games will run on GeForce GTX 1660. The TU116 graphics processor is an average sized chip with a die area of 284 mm² and 6,600 million transistors. Unlike the fully unlocked GeForce GTX 1660 Ti, which uses the same GPU but has all 1536 shaders enabled, NVIDIA has disabled some shading units on the GeForce GTX 1660 to reach the product's target shader count. It features 1408 shading units, 88 texture mapping units, and 48 ROPs. NVIDIA has paired 6 GB GDDR5 memory with the GeForce GTX 1660, which are connected using a 192-bit memory interface. The GPU is operating at a frequency of 1530 MHz, which can be boosted up to 1785 MHz, memory is running at 2001 MHz (8 Gbps effective).
Being a dual-slot card, the NVIDIA GeForce GTX 1660 draws power from 1x 8-pin power connector, with power draw rated at 120 W maximum. Display outputs include: 1x DVI, 1x HDMI 2.0, 1x DisplayPort 1.4a. GeForce GTX 1660 is connected to the rest of the system using a PCI-Express 3.0 x16 interface. The card's dimensions are 229 mm x 111 mm x 35 mm, and it features a dual-slot cooling solution.
GTX1660
GV-N1660CN-6GD
GTX1660
GV-N1660CN-6GD
- GeForce GTX 1660 PG161-A01 - 600-1G161-BASE-100.pdf (948.9 KB, 992 views)
- MSI GeForce GTX 1660 SUPER Gaming X MS-V375 Rev2.2.pdf (1.03 MB, 150 views)
