Powercolor rx 6600 stuttering (HW ISSUE)
  • slayernn
    • Jul 2018
    • 45
    • Serbia
    Hi! I have troubles with rx 6600, and at begining to eleminate anything related to software level,oc/dc,vref up/down,temperature etc etc, tried everything imaginable!
    Card work perfect in benchmark/stress (also vram test pass) apps but in games, it stutters/freeze/crash etc, sometime not starting game. On same setup(i5-6600k etc) i run gtx970 and eveything is perfect. Now my last resort is trying to figure out if its posible to fix card and what can be wrong on it. Or its just simply issue in GPU and in short: dead card? Im not noob and not pro when it comes to electronics so any help would be great! Best regards
    AMD Radeon RX 6600 XT (RX6600XT) Schematic & Board View
    The Radeon RX 6600 XT is a performance-segment gaming graphics card by AMD, launched on July 30th, 2021. Built on the 7 nm process, and based on the Navi 23 graphics processor, in its Navi 23 XT variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on Radeon RX 6600 XT. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The Navi 23 graphics processor is an average sized chip with a die area...
    10-01-2024, 12:10 PM
  • rounin
    MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
    by rounin
    I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
    🛠 Original Issue
    The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
    ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
    04-19-2025, 01:18 AM
  • ugamazing
    Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
    by ugamazing
    I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
    We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
    12-17-2024, 07:05 PM
  • ahmarzo
    Acer laptop battery draining issue
    by ahmarzo
    Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
    Help me to diagnose this issue as there is no shortage in the inputs MOSFET
    08-02-2025, 06:39 AM
  • teryeah
    Powercolor AXRX 6600, help to find what components is missing
    by teryeah
    Some components have broken off the PCB. Anyone with the same that can check what's missing?...
    10-22-2023, 07:57 AM
