1 bad cap on motherboard
  • blasterboomer
    • Dec 2013
    • 135
    Hi i have a gigabyte mobo which i pulled from a pc i got given and it all looks good except one cap which was bulged and leaking. all the rest of the caps are nichicon and sanyo so they should be good but the cap thats bulged is by itself next to the cpu at the right and its a kzg cap but i wont be able to test for a while so i was wondering if its worth buying a psu to test it. the cpu is a pentium 4 (dunno what speed or anything all i know is thats its lga 755), 2x512mb ddr1 ram (samsung) and an old ati radeon gpu i think its a ati radeon x400 or something like that, i know the gpu is probably complete crap for anything these days but does anyone think its worth fixing up which means getting a psu and hard drive (i have a case)
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Re: 1 bad cap on motherboard
    What would you plan on using it for? I think it's worth fixing, you'd want some more RAM though. Unless you're running linux, 1GB can't do much. You'd want at least 2GB in there for Windows 7. Video card should be fine if you aren't gaming, and you can turn Aero off to improve performance. What's the model of the Gigabyte board? You want to replace ALL of the KZG, they will all fail eventually if you use the computer.
    • blasterboomer
      • Dec 2013
      • 135
      it would probably be used as a fileserver of some sort or just to test hard drives etc strangely theres only one kzg cap on the whole mobo and thats the one thats failed. all the rest are nichicon and 3 are sanyo. also if the computer works with that bad cap will it be ok to continue using it or would it just blow up eventually
      • blasterboomer
        • Dec 2013
        • 135
        the motherboard is a gigabyte ga-8i915pm-fs the bad cap can be seen in this pic (not mine but similar to the one i have ) http://cache-cdn.kalaydo.de/mmo/5/41...1215165026.jpg its the cap near the cpu socket at the left the one by itself
        • blasterboomer
          • Dec 2013
          • 135
          nvm swapped it for an asrock mobo with dead southbridge, the mobo had 2x4gb ddr3 ram and an intel core i5 which both work so all good, i now have 16 gig of ram in my pc
          • glovecaps
            by glovecaps
            11-25-2024, 04:23 PM
          • Docus
            Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
            by Docus
            Hi everyone 😀,
            I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
            To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
            Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
            1. I already own the exact same model, but its plastic chassis is badly damaged.
            06-10-2025, 04:24 PM
          • Archimedes
            HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
            by Archimedes
            Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
            Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
            Fans are spinning. Blindly could install windows11 and got the device manager...
            07-30-2024, 05:14 PM
          • dragon3x
            by dragon3x
            power on.
            Here are some examples :
            switching supply area).
            than 6.3 V.)
            03-21-2025, 02:46 PM
          • dhenion
            Asus VivoBook F510UA-AH51 won't run on battery after motherboard replacement
            by dhenion
            I'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
            The original board was:
            ASUS X510UNR REV 3.0 A
            The replacement board is:
            ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
            It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...
            01-30-2024, 01:45 PM
