intel G31PR freezing after heatup
  • srt1
    • Aug 2013
    • 177
    • india
    i have an intel g31pr montherbaord. when it in cold boot its working perfectly after almost 10 mintues it freezes then when i restart it giving memory beep.i am sure its not because of bad memory i changed lot of memories same problem coming .. to get the board work again need to cool down about 15 mintues. is it beacuse of bad caps? i could not find any bad caps. please answer me
  • T30M31
    • Feb 2014
    • 58
    Re: intel G31PR freezing after heatup
    Are all of the cooling fans working?
    Does it have a fan to pull air over the CPU heat sink?
    Do you have software installed that will monitor the CPU temperature and if so, what is the CPU temperature?
    If you have a can of component cooler or compressed air you can use that to cool down the CPU heat sink and see if that will help it restart in less than 15 minutes.
    • srt1
      • Aug 2013
      • 177
      • india
      the motherboard is not in case i placed on table mean breadboard.. so south bridge have littile bit hot but i place an heatsink over it. cpu temperature is noramal around 50 degree in bios and fan is working. also somtimes mb not freezing but wen it restrt it giving memory beep
      • T30M31
        • Feb 2014
        • 58
        After 10 minutes of operation does the CPU temperature still read 50 degrees?
        I would use a fan or component cooler to cool different parts of the board to isolate the problem. Try cooling the memory modules, CPU, south bridge, and anything else that seems hot to see if you can get it to run more than 10 minutes.
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          If there are no bad caps, i would suspect that there is a problem with the Northbridge. You could try reflowing it.
          A working TV? How boring!
          • actlt
            • Mar 2014
            • India
            Check and changed SMPS some time bad caps of smps make Mobo Frz..
            • srt1
              • Aug 2013
              • 177
              • india
              cpu temperature is normal around 50 to 55 degree in operation south bridge have hot but i place a fan over it but problm stil thr .board is worked without freezing many times. .i check it 30 minites 45 mintus etc. but problm is wen i restrat it giving memory beep even 10 mintues of on condition. is it also i am using a debug pci card in pci slot .but its not displaying any code showing always 00 code wen it posting. i have same another g31pr mb. it giving all post codes.
              • T30M31
                • Feb 2014
                • 58
                Is the mother board an Intel Dg31pr ?
                Can you tell me who makes the memory and the part number of the memory modules?
                Please try this when the computer has cooled down.
                Start computer and let it run 10 minutes.
                Turn off the computer and remove AC power cord for 2 minutes.
                Connect AC power cord and start computer.
                Does it give memory beep now?
                • srt1
                  • Aug 2013
                  • 177
                  • india
                  i changed smps same problem stil thr
                  • srt1
                    • Aug 2013
                    • 177
                    • india
                    yea mb is dg31pr intel make. i found another things right now. i have lot of ddr2 rams different make and different size. out of these only two rams working perfectly without any problem . that ram is kingston make part number is KVR667D2N5/1G. - 667MHZ AND 1GB SIZE. this ram not giving problems. but all other ram working on cold boot. but all othr rams are working perfectly on other boards also on my another dg31pr. i turned off and wait for 2 minutes but stil giving memory beep at same time i tried kingston ram. it is working
                    • T30M31
                      • Feb 2014
                      • 58
                      That Kingston ram is on the Intel list of memory modules that have been tested to work with the DG31pr mother board.
                      This is a link to the Intel memory list.
                      http://www.intel.com/support/motherb.../CS-027918.htm
                      I am glad you solved the problem.
                      • srt1
                        • Aug 2013
                        • 177
                        • india
                        Thanks for everyone who replay for me. Especialy for T30m31. But i have doubt is it only memory compatible problem? I have hynix and some other brands it giving beep problms
                          master hoarder
                          • May 2008
                          • 12175
                          Try running the memory at a slower clock and more lax timings. See if that changes anything. Unless you have genuine Hynix RAM (i.e. not just Hynix chips on the RAM module, but also proper info in CPU-Z), the module could be made from binned RAM chips, so there's no 100% guarantee it will work at the advertised speeds.
                          It could also be the BGA joints on the NB as Th3_uN1Qu3 suggested.
                          • srt1
                            • Aug 2013
                            • 177
                            • india
                            thanku..
