MSI 815E Pro (MS-6337)w pics - Email MSI and their response.
  • capsaredumb
    • Aug 2004
    http://www.flashstudios.net/MSI815eP...ps/BadCaps.htm
    Every single one of these !&#)$(*&!@)(#&$!@(&#$ I.Q. caps are bulging and/or leaking. It's a wonder the thing was actually running when I replaced it with a used Asus Tusl2. (which is also unstable btw. *sigh*)
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Hey I had the same board but no way did i have the carnage that your board did. My caps visibly failed near the atx connector. It was pretty unstable at that point. I also bought a TUSL2 as I was a fan of the CUSL2 series. But the quality of caps was dissapointing on the TUSL2, i forget what they were. Actually I have only one CUSL2 with totally rubycon caps. The others I have are a mix of Rubycon and some shit.
    Hope you recap your boards successfully. I think it will be worth it. Apart from the 512mb ram limit that chipset is still one of my favourites.
      HP Elite 8300 computer completely locked no response from key board or mouse
      Dose anyone know what would cause this issue because I do not understand what is going on
      The setup is the hard drive is set to never turn off
      The video set to not turn off
      Supposedly it setup is not to power down at all but something is not working correctly
      I have three of these computers and the other two work correctly with this setup
      The video is on the screen but the keyboard has no lights on and no response the mouse light is on but no response to movement
      The power button does not respond correctly either because if...
      06-19-2022, 07:49 AM
    • rumpumpel1
      Lenovo L480 NM-B461: strange power delivery response
      by rumpumpel1
      I have a L480 board with a working USB-C port and a non-working docking port that only runs on 5V. I have replaced the TB-Bios but to no avail. Both ports show 0,6V in diode mode. My Kingst Logic Analyzer showed the following strange response.
      The charger offers correctly 4 voltages:
      0.8781038000,Header,(8589951393),DataObject:4 Source V3 DFP Source_Capabilities
      0.8781686000,PayLoad[0],(168923436),V:5V Imax:3A
      0.8782978000,PayLoad[1],(1233196),V:9V Imax:3A
      0.8784272000,PayLoad[2],(1356076),V:15V Imax:3A
      0.8785566000,PayLoad[3],(1458501),V:20V Imax:3.25A​...
      07-23-2024, 06:17 AM
    • Abdiko
      Toshiba prostege R830 bios response code
      by Abdiko
      I have Toshiba prostege R830 and I forget bios password
      Is there any one who help me to reset
      Pc serial number=5C086947H
      Challenge code=C26T7-M8M1R-CUL2X-UAQN6-6FLMD
      Please I'm waiting for you for response code
      Response code=?
      08-29-2022, 03:00 PM
    • mptcultist
      XPS 7590 1.5v on ALWON no response from power button.
      by mptcultist
      Hi, a few years ago I bought an xps 7590 and about a year ago the motherboard on it failed. I've been trying to diagnose the issue for the past few days.
      The things I have noticed that seem relevant are that ALWON is 0.0v, and ACAV_IN is 1.6v. Tracing back to PU1901 seems to show that the logic gate there is receiving the appropriate inputs and VCC. If I short VCC to the output with my probe, the other side of the gate will rise to 3.0v, and then RTC voltage will rise to 2.2v. The MEC will then get quite hot, and after about 20 seconds, the RTC voltage will fall to 0.4v, and the other...
      02-08-2024, 03:22 PM
    • nubie
      Strix B450-F Gaming no response, missing components.
      by nubie
      No response at all to the power button. No debug LED or fan. Nothing getting hot.
      I've got 0v on one power button pin and 3.3v on the other. When I jump them 3.3v pulls low.
      I tried 9700E processor and R5 3600
      Missing these parts near IT8665E. Any Idea what they were? Thanks.
      11-28-2023, 05:49 PM
