Gigabyte GA-7DX+
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    Gigabyte GA-7DX+
    Caps are not visibly failed, but are OST's, so they're getting replaced now to prevent future issues.
    Cap count?
    (4) 3300uf 6.3v
    (3) 1200uf 10v
    (8) 330uf 25v
    I have to ask, why the need for 25v rating?
    Ludicrous gibs!
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    Re: Gigabyte GA-7DX+
    Tested the board before recapping... no post.
    Recapped anyway, still no post.
    Tried all the culprits, CPU, FSB speed, RAM, Cards, drives/nodrives... simply won't post. Board was a freeby and was not known to be working, so I'm pulling my good caps back off and trashing the rest. Oh, but I will keep that massive NB heatsink
    Ludicrous gibs!
    • gdement
      • Jan 2007
      • 690
      Did you try switching to the backup BIOS?
      • Big Pope
        Approved Vendor
        • Dec 2005
        • 426
        Clear CMOS yet? CPU heatsink fan have power or not when short PWR ON jumper?
        My SAMXON Capacitors Database HERE!!
        X-CON is a new brand for SAMXON's Polymer Capacitors.
        • dood
          Deputy dood
          • Mar 2004
          • 2462
          1. Backup BIOS it supposed to be activated automatically when the main BIOS fails. There's no hard switch that I know of.
          2. As such, there's no clear CMOS jumper, either. I did pull the battery (with the PSU off) and short the contacts, but that didn't help any.
          3. As soon as I turn the PSU on, the board fires up and sits there humming along. I can then shut it off, but only by shorting the power on spot for 5 seconds. Once it's off, it will stay off, but firing it back up still won't get it to POST.
          Ludicrous gibs!
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            measure vcore.
            might be a dead cpu.
            see a lot of bad amd .
            they are fragile.
            • dood
              Deputy dood
              • Mar 2004
              • 2462
              I've also tried it with two different known good CPUs
              an Athy XP 1500+ (133mhz FSB)
              an Athy 900mhz (100mhz FSB)
              And yes, I did have the FSB jumper set correctly both times
              Ludicrous gibs!
              • Big Pope
                Approved Vendor
                • Dec 2005
                • 426
                It seems short circults, need to cheap voltage of the compents by a multimeter. Hwoever, that's need many of repair experience. I think you should a little experience at this level, so give up.
                • dood
                  Deputy dood
                  • Mar 2004
                  • 2462
                  LOL, thanks for the vote of confidence, Joe.
                  Ludicrous gibs!
                  • Big Pope
                    Approved Vendor
                    • Dec 2005
                    • 426
                    Sorry for typing mistake, lol.
                    cheap = check
                    Hwoever = However
                    • shadow
                      • Feb 2007
                      • 732
                      Nice work on putting that nice Northbridge heatsink on the GA-7VA shown in the other thread!
                      • dood
                        Deputy dood
                        • Mar 2004
                        • 2462
                        Actually, both boards came in with those 'sinks on them.
                        Ludicrous gibs!
                        • DynaxSC
                          GIGABYTE GA-H110M-S2 - Stuck at Debug Code C2 - don't like Patriot Viper Steel RAM but works with G.SKILL
                          by DynaxSC
                          I discovered a strange behaviour of GIGABYTE GA-H110M-S2 board.
                          General test conditions:
                          - Tested with Core i5 6500 and Core I7 6700K - no difference
                          - Default BIOS settings, but tried also altering several memory setting - does not change anything
                          What is wrong:
                          With BIOS F1 and F2 the board normally POST's and boots to Windows 11 with 2 x Patriot Viper Steel PVS416G440C9K RAM (4400MHZ, Samsung B-Die chips)
                          When BIOS upgraded to anything above F2 (ie. F20-F27b) the board POST stucks after 3 Debug Codes on Code C2
                          03-21-2025, 06:23 PM
                          Thermal pad thickness for various laptop GPU / Graphics Cards
                          ASUS Dual RTX 2070 OC 8GB
                          ASUS ROG STRIX RTX 3080 OC
                          ASUS ROG STRIX RTX 3090
                          ASUS TUF Gaming RTX 3080 OC Edition
                          ASUS TUF GTX 1660 S-O6G GAMING
                          EVGA RTX 3060 Ti XC GAMING 8GB
                          EVGA RTX 3060 XC GAMING 12GB GDDR6
                          EVGA RTX 3080 FTW3 ULTRA GAMING
                          EVGA RTX 3080 TI FTW3 ULTRA GAMING
                          EVGA RTX 3090 XC3 ULTRA GAMING 24GB
                          Gainward RTX 2080 Phoenix GS Specs
                          Gainward RTX 3070 Phoenix 8GB
                          Gainward RTX 3080 Ti Phoenix
                          GIGABYTE AORUS RTX 3080 MASTER 10G
                          02-09-2024, 08:08 AM
                          A Dead/DOA Gigabyte GP-P450b 450W ATX PSU
                          by momaka
                          More eBay specials: this time a Gigabyte GP-P450b 450W ATX PSU for $8 with free S&H. Listed “For part/not working”, as usual. Showed up in a beat up EVGA box without any padding… but that's understandable given the total price. PSU made it out fine without damage. It's a non-modular (yay!), pretty modern-day looking PSU with a black paint and all black cables (meh, not my favorite, but figure it's good to keep a few of these in case I do need one for a more modern PC build, just so my old gray boxes don't look too odd in there.)
                          And a shot of the label:...
                          01-26-2022, 03:26 AM
                        • nikovmiroslav
                          Gigabyte A5 X1 Need Bios
                          by nikovmiroslav
                          Hi Everyone,I need help with this strange Gigabyte laptop,it turns on with black screen and after 30sec fans on the Max for few seconds and it shuts down,I think the bios is bricked,They say it is Clevo under the hood,there is nowhere on motherboard what is the model which is strange,i will write S/N and P/N from the motherboard,thats only what is writen there and upload old bios,if anyone can help,Thanks!
                          Gigabyte A5 X1
                          From motherboard:
                          S/N: 1TNH55ER1350895
                          P/N: 6-77-NH55ERQY-D02-2CGB
                          On sticker from the back of the laptop:
                          S/N: SN21351J000657...
                          08-24-2025, 09:15 AM
                          Gigabyte AERO 16 XE5-73UK948HP Notebook Specification for Upgrade or Repair
                          This specification for the Gigabyte AERO 16 XE5-73UK948HP Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 XE5-73UK948HP boardview and 16 XE5-73UK948HP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                          09-07-2024, 07:19 AM
