M2 Sata SSD failed - important data exist
  • cekcons
    • Mar 2022
    • 15
    • turkey
    hi everyone ! I do have a faulty ssd its m2 (sata i do belive). When i plug in to board and boot my pc it stucks on bios forever. I unplug it and it boots fine. I tried usb adapters etc still no dice.
    But I found out that i can enable "ROM" mode (?) by shorting two debug pings at back of ssd. Now i can boot and it shows up as a 1gb drive on my device with "not started" mode. Name that it showed up is : SM59XT2A-80-10000001
    ​My ssd brand is "TWINMOS" which is i do belive just a china rebrand. it is a 256 gb drive. only two storage chip on the thing. I checked if any short etc. didnt find anything all voltage seems fine.
    Anything helps. Thanks.
  • DynaxSC
    • Apr 2021
    • 465
    • Poland
    I would not see a lot what can be done. Try another m.2 port - usually only one m.2 port on a mobo supports SATA mode. Try usb adapter for m.2 disk.
    Always do backups for important data, and don't buy nonames/chinese disks they are usually crap.
    • rogfanther
      • Jul 2006
      • 458
      • Brazil
      If the data is important, better to send it to a specialized data recovery firm, than risk destroying the data while you learn.
      • Aliencomputres
        • Aug 2019
        • 208
        • România
        Try a adapter usb/m2 .
        • DynaxSC
          GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
          by DynaxSC
          I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
          There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
          The board is generally working now, all PCIe ports are working, Windows installs normally.
          However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
          The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
          03-10-2025, 12:27 PM
          HP Z2 G4 + 3TB SATA 6Gb/s 7200 HDD i7-8700K Specification for Upgrade or Repair
          This specification for the HP Z2 G4 + 3TB SATA 6Gb/s 7200 HDD can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Z2 G4 + 3TB SATA 6Gb/s 7200 HDD boardview and Z2 G4 + 3TB SATA 6Gb/s 7200 HDD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
          09-12-2024, 03:28 PM
        • clabr
          Lenovo 11e problems (any sata hdds are not recognized, sleep battery drain)
          by clabr
          Need help to solve some problems with this laptop.
          After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
          After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
          Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
          Before this had happened I observed some other problems:
          When I tried replacing original mecanical HDD with a SSD HDD could not get them...
          12-02-2021, 08:09 AM
        • playit
          psu sata power wires thinner - does it make a difference ?
          by playit
          hello , i have a psu 450 zebronics (yes its bad crap) which used to work before with its own sata power cable ,but today its not able to power up harddrive efficiently with its own power sata cable , but when there is a connector which have a thick wire than the psu sata power cable wires - its powering up and working smooth , no problem yet .
          i the voltages with multimeter shows 12 ,3.3 v , no problem , but hardrives powers well only with this thick wire sata power cable connector from psu power molex .
          any explanation on this ?? thank you ,soon i am planning to buy some branded...
          10-12-2023, 05:25 AM
        • kokodin
          HP stream 14 ax series laptop - restoring sata
          by kokodin
          Hello, i have started a wierd project out of curiousity.
          HP stream 14 ax laptop, which normally have no storage other than emmc chip have also some unused footprints for m.2 socket. Space in the case is also provided for a gumstick ssd, so i decided to hack something in.
          After studying schematics and board view files i was able to figure some of the things out. Poorly install a connector on my 4th atempt, but it works :P
          restore sata line termination caps and move specyfic jumpers on the board to make ssd not emmc as a expected system drive.
          02-21-2023, 02:58 AM
