b450m pro-vdh plus ms-7a38 ver 7.0 power up doesnt beep cpu led on only
  • jonny0404
    • Nov 2014
    • 116
    • Colombia
    hi guys i have these board that doesnt get any video, it doesnt beep, i replace memory ram and i have 2 cpus one is aTLON3000G AND THE other one is rizen 1600, i try both i flash bios, on memory module i have vdp spd 3v i have voltage 1.2v the only voltage that i dont see is MB_RST pin 58 on memory , can some one tell me where else i can measure i have the boardview here ..
    https://www.badcaps.net/forum/troubl...-7-0-boardview
  • Ymotaqi
    ROG STRIX Z590-A GAMING WIFI has no POST no BEEP no diag LED
    by Ymotaqi
    The motherboard does not POST and has the following symptoms:
    When the power button is pressed, the fans and RGB turns on.
    When the power button is pressed, the motherboard voltages 12, 5, and 3 are connected.
    The motherboard does not beep.
    None of the diagnostic LEDs light up.
    USB voltage is off.
    VCORE voltage is off.
    The BIOS software was downloaded from Asus site and installed using the Q FLASH button, but it made no difference.
    I would appreciate it if anyone could guide me on the cause of the problem.
    01-12-2025, 04:15 AM
  • MisterAIL
    PS5 digital / No Power / No Beep / Good power supply
    by MisterAIL
    Brought a non functionnal PS5. Apparently only a bad PSU...
    No beep, nothing.
    After some tests i found this :
    - PSU is fine (12 volts stable)
    - 12 volts line is shorted
    - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
    - By the way, nothing change. No signal, no power, no beep.
    Mesuring all rails with my workbench psu (12 volts input)
    - 0.00 amp drawing
    - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
    03-12-2024, 03:24 PM
  • WVUfan
    PS5 EDM-033 One Beep,No Lights, No Power Troubleshooting Help
    by WVUfan
    hello. i've a ps5 edm-033 mobo w/ no power, lights, but one beep when power pressed. i've hooked to uArt and only error code is 80871001 (DDR4 No Power or Short Circuit). i have a donor board, same model, that does power up, fan spins, blue light, and beeps 3 times, then powers off. it has a botched HDMI port replacement job. so w/ the board i'm interested in, with the error 80871001, i was able to research and obtain voltages of the SSD PMIC. i've attached pictures of the provided diagram by DylanBBK (@d62 on Discord) and my voltages and picture of my board. my question is on my picture...
    08-11-2025, 01:12 PM
  • nolaryie
    BIOS .bin file for ASRock B450M Steel Legend
    by nolaryie
    Hi, I’m looking for a clean, working BIOS .bin dump (16MB) for the ASRock B450M Steel Legend motherboard.
    I’ve already tried flashing the official ASRock ROM file via CH341A, but it won’t post — I believe the capsule format is incompatible.
    Any BIOS version that supports Ryzen 5 2600 is fine (e.g., P2.30–P3.60).
    If anyone has a working board and can dump the BIOS using CH341A or flashrom, I would really appreciate your help.
    Thank you!
    08-06-2025, 12:01 PM
  • ktmmotocross
    Ps5 pro - one beep and not start after hdmi port change and decoder ic reflow
    by ktmmotocross
    Hello.
    Have this ps5 pro EDM033 that came with damaged hdmi connector. i replace it and console works for few days but show hdmi problems when cold start. so cold joint. reflowed connector and decoder ic as i think he have cold joint. but now i have only one beep and no start. can heatdamage of this decoder ic prevent start?
    i have ps5 repair guide but not ps5 pro so link me to it if u know it
    04-27-2025, 01:10 AM
