You can do these tests:
1. Turn on the iMac and press and hold the D key to start diagnostic mode, if it does not load, turn off the iMac.
2. Press and hold the shift key (⇧) to boot into safe mode, if it doesn't work, turn off the iMac.
3. With the IMac turned off, hold down Command (⌘) + R, press and release the power button, and continue holding Command (⌘) + R until the macOS built-in recovery system appears.
4. If you can access the macOS recovery system, locate the Utilities menu in the top bar and click on Terminal in the submenu.
5. When you are in the Terminal window, type date and press enter and write down the date/time, make sure it corresponds to the current date/time. If it is on a very late date/time, the system will not load, you can update the date/time using the same date command in Terminal:
date 1022130016 and hit enter.
date (month) (day) (hour) (minutes) (year)
6. If you cannot access it with the previous method, you will need a boot disk. It can be macOS Catalina, Mojave or High Sierra. If this is the case, turn off the iMac.
7. With the iMac turned off, insert the macOS installer into one of the USB ports and press and hold the Option (⌥) or Alt key to load the Boot Manager. Turn on the iMac and hold the key combination until the boot manager appears and select the external drive (macOS installer) that you previously inserted.
If the installer does not appear, while you are in the boot manager, remove the installer and plug it into another port until it appears, then select it to boot from that drive.
Once it loads, you will reach the external installer macOS recovery system, repeat steps 4 and 5 above.
8. If you don't have a compatible installer for this iMac, you can try pressing Command (⌘) + S at power-on to make it boot into Terminal mode. If you can get to this mode, go to step 5 to check the date/time, if it is behind, update with the commands that I wrote down, if you cannot change the date/time in this mode, you could try deleting the user's account, this We leave the last one for another occasion so as not to prolong these tests.
Previous considerations:
If you use a wireless keyboard, make sure the batteries are charged.
If you use a wired keyboard and do not take any key combinations, make sure that the iMac does not have a firmware password activated, if this is the case, the keyboard will not work and you will not be able to do any of the above.
Good luck!
iMAc 27 inch late 2013 EMC 2639 no boot
I will do these procedures, thank you.
The iMAc crashes at the beginning, it doesn't reach the password screen or the desktop.Leave a comment:
Try taking out a stick of RAM one at a time to see if it's that causing the problem.
Also run ASD to check the iMac fully.Leave a comment:
have you cleared all of the nvram and smc.. also have you tested your ssd. if all else fails, then there is likely a hardware failure that is not being detected by the internal diagnostics. are you able to read the install log?
After installing the OS via the internet, it restarted and crashed at the logo1 PhotoLeave a comment:
Ok. So, I'll try to install native OS, via the internet.
Then I'll post the result hereLeave a comment:
I doubt it's the GPU. It would just reboot.
Looks more like a bad installer. Try a fresh Catalina USB installer stick.Leave a comment:
Yes, I tested with an external SSD on USB with High Sierra and it hangs on the Apple logo.
I think I'll try a reflow on the GPU and it works, reballingLast edited by Sergio Kub; 01-23-2024, 05:24 PM.Leave a comment:
hi,
Is that a 14,2? make sure you are using Catalina or below.. before you start experimenting with the gpu.Leave a comment:
Yes, it can't load the OS, but I put an external SSD on USB with High Sierra and indicated on the keyboard to start with it and it stuck on the Apple logo... Maybe GPU?Leave a comment:
Hi there,
That does not seem like a bios situation, more like an OS problem.Leave a comment:
Hello, I have an iMAc 27 inch late 2013 EMC 2639 at work that doesn't start, it has a prohibited symbol and/or when I connect the system via USB it stops on the apple.
Is this feature locked in the bios?
Thanks in advance1 PhotoTags: None
by tyl85Hi, i have this iMac issue
I've checked temperature by using macfans with no results
techtool pro shows me AMBIENT AIR TEMP FAULT
i'm going crazy, the mac runs very slowly
where i can find this sensor on motherboard?
thanks in advance
by StephenCustomer came in for data recovery, came to find out data is soldered on to this iMac (learn something new everyday) this is a 2020 T2 iMac so I was surprised because the iMac Pro has a T2 chip and it isn’t soldered on. Anyways, the iMac boots to Apple logo and then restarts, before it turns off you hear a quarter fan spin then it repeats itself. I decided to do a DFU revive to restore any hardware firmware issues and it was successful in reviving the device however the issue persists in boot looping. It shows the Apple logo for like 40 seconds then turns off and fan spin rinse repeat. I...
by Gigabit2I have a late 2013 MacBook Pro 15" here, with light on charger but does not boot with or without battery installed. Can anyone provide assistance?
I checked these rails:
PPDCIN_G3H - 19.80 (20V mode)
PP3V42_G3H - 3.41 (20V mode)
PPBUS_G3H - 12.56 (20V mode)
PP3V3_S5 - 3.32 (20V mode)
These look okay to me, where should I look next? -
by ElewaysHi there
An iMac A1418 late 2013 (but same problem on an A1419 too).
It works but very slow. Fan start to run after few second you turn on the iMac.
I've spoke with a friend in Apple, and he tell me about a sensor defective, but they usually replace the motherboard to fix the problem.
This iMac have no sensor (only one on the display), so I presume he means about a sensor on the motherboard.
Anyone have same problem? any idea about to solve?
Thanks and best regards.
Luke -
by BraithHi, EMC 2639 .iMac not starting up. Single dim diagnostic LED (LE0301) flashes off briefly when power button pressed. Working through supply rails at present (PP5V_S5 appears shorted to ground but still early days)
Using Boardview 820-4652 but not sure if that is correct one to use. Have searched Forum but only found bios found for 2639 so far.
Have also tried 820-00134-08 and 820-3478 but have noticed discrepancies compared to my board.
If anyone has correct BOARDVIEW and SCHEMATIC for a EMC 2639 I would really appreciate it before I get too far into this.
... - Loading...
