Jetway bad cap and class settlement?
  • supersabre
    • Feb 2006
    • 45
    I have a P4 Jetway mobo with many bad, bulging caps. it is manfactured in 2002.
    According to http://www.jetwaysettlement.com, i have to submit the claim form in order to qualify.
    Do i need the invoice for the board?
    Have anyone try the claim from?
    Does it work?
    How long does the whole process take?
  • madan1
    DALI SUB E-12F class D, fluctuating power rail
    by madan1
    Good day everyone.
    I have on the bench an amp board from DALI SUB E-12F. It is class D amp with a smps on the same board.
    The issue is that it powers off way before the rated power is reached (the protection circuit kicks in). It has an independent standby power supply, which stays on after the main power supply is turned off via a relay on the primary side (thus there is no reason to believe that the protection is triggered from the smps IC on the primary side).
    The normal value of the positive and negative power rails is +/- 43V.
    The positive rail stays...
    10-15-2025, 10:33 AM
  • dicky96
    What 'class' is this Hill Audio DX3000 Amplifier?
    by dicky96
    Hi guys, this is general query really
    So I have a Hill DX3000 3KW audio amplifier here.
    It has a topology/design like a class A/B but all the banks of output transistors (10 transistors in each 'side' of the channel) are NPN.
    I was wondering what class this is. It doesn't fit the description of class A.
    It also doesn't match class A/B or B amplifiers as all the examples I see have a complimentary output stage desigs (NPN/PNP) and clearly is not G, H or D
    I looked for 'class A push pull' but that didn't tell me anything either
    05-04-2022, 04:20 AM
  • japlytic
    Certain "Class 2" HDMI cables can be marginal at 4K 60 Hz
    by japlytic
    For some time, a "Class 2" HDMI cable (part number BN39-01583B) supplied with a Samsung 4K 60 Hz display sometimes causes the display to overlay a few horizontal lines of flickering pixels of random colours and sometimes drops out, particularly on content requring HDCP.
    Since changing the cable to a thicker Class 2 unit, this problem has not occured again - do you know of other marginal "Class 2" HDMI cables supplied with displays?
    09-06-2023, 08:50 PM
    Jetway 845LDA Motherboard Schematic
    Jetway 845LDAL is a motherboard based on the Intel 845GL (Brookdale-GL) chipset....
    11-05-2024, 12:10 PM
    Jetway 845GDM Motherboard Schematic
    Jetway 845GDML is a motherboard based on the Intel 845G (Brookdale-G) chipset....
    11-05-2024, 04:36 AM
