Changing the processor on the X470 board
This topic has been answered.
  • UNITRAX
    • Jan 2023
    • 64
    • POLAND
    I have the following setup:
    Msi X470 gaming plus, ryzen 3 2200g
    2 x 16 Gb hyper x cl17, radeon rx 570 8Gb
    I would like to change the processor to r5 5600 or r5 7600
    Which one is best to choose?​
  • Answer selected by UNITRAX at 01-28-2025, 04:13 PM.
    LozinMust
    • Apr 2023
    • 24
    • Portugal
    You just need to make sure that you have a BIOS version compatible with the new CPU. According the MSI website (https://www.msi.com/Motherboard/X470...US/support#cpu) you will need version 7B79vAL or later to be compatible with the 5700X. As such, I suggest you flash the latest available BIOS version before swapping the CPUs. I think that's the only thing, everything else should work just fine.
    • LozinMust
      • Apr 2023
      • 24
      • Portugal
      Your motherboard is AM4, so only the R5 5600 would be compatible. For the R5 7600 you'd need to upgrade to an AM5 motherboard.
      • UNITRAX
        • Jan 2023
        • 64
        • POLAND
        Price difference between r5 5600x and r7 5700x is small and I prefer to buy r7.
        Regnum RG4T case provides 159mm for CPU cooling.
        Which model will be better Noctua NH-U12A, or be quiet! Dark Rock 4 135mm?​
        • LozinMust
          • Apr 2023
          • 24
          • Portugal
          Yes, the R7 5700X is probably the better choice. Keep in mind, however, that neither of those has integrated graphics, unlike the 2200G you're replacing, which can be nice for troubleshooting. If that is important to you, you can go with the R7 5700G, but it is a bit slower than the 5700X.
          About the cooler, I'm running a Thermalright Peerless Assassin with an R9 5900X and it works very well. It is also considerably cheaper than the ones you suggested but the height might be a bit close (it's listed as 157mm on Amazon). You can check the list of reviewed CPU coolers by Gamers Nexus (https://gamersnexus.net/megacharts/cpu-coolers), which is quite informative and see if there are any options that suit your needs.
          • UNITRAX
            • Jan 2023
            • 64
            • POLAND
            Now I have integrated graphics, but I also have a dedicated card that will remain in the set, over time I will change the RAM and GPU.
            What problems may occur after changing the processor?
            Thank you for the link in your post.​
            • LozinMust
              • Apr 2023
              • 24
              • Portugal
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
              • m1ch43lzm
                by m1ch43lzm
                05-12-2025, 08:37 PM
                AMD Radeon RX 5600 XT (5600XT) Schematic & Board View
                The Radeon RX 5600 XT is a performance-segment graphics card by AMD, launched on January 21st, 2020. Built on the 7 nm process, and based on the Navi 10 graphics processor, in its Navi 10 XLE variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX 5600 XT. The Navi 10 graphics processor is an average sized chip with a die area of 251 mm² and 10,300 million transistors. Unlike the fully unlocked Radeon RX 5700 XT, which uses the same GPU but has all 2560 shaders enabled, AMD has disabled...
                10-01-2024, 10:42 AM
              • Hakuu
                by Hakuu
                Hi There,
                More Details
                TV Model - LG OLED77G1PUA
                07-12-2023, 02:37 PM
              • jb_Bak
                by jb_Bak
                CN6401
                Pin 01 NC
                Pin 02 NC
                Pin 03 "BL_ON": 0V
                Pin 04 "N/C"
                Pin 05 "STBY 3.3V": 3.5V
                Pin 06 "GND": N/C
                Pin 07 "AC_OFF"...
                09-27-2021, 04:52 PM
