No Post Asus P5Q
  • Mikeyboy2007
    • Mar 2013
    • 745
    • Scotland
    No Post Asus P5Q
    hi there guys replace core 2 duo with core 2 quad and new heatsink, could not get a post, tried reseating ram, pulling CMOS battery etc still no post, replaced with original components and still cant get post now, any ideas ?
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: No Post Asus P5Q
    Sounds like the socket got F-ed up, especially if it don't even make a bleep.
    I swear you almost need a clean room to handle LGA 775! 775 may break if you even breathe a certain way.
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • Kiriakos GR
      Banned
      • May 2012
      • 940
      • Greece
      My main system is a P5Q with Q6600 quad plus 4GB of ram and runs great.
      You better get a magnifier and inspect all the CPU socket pins for been bended or misalignment ed .
      Your repair tool should be nothing bigger than a stitch needle
      • Mikeyboy2007
        • Mar 2013
        • 745
        • Scotland
        there is no Speaker on the Mobo, alot of other people seem to have same kinda issues
        • Mikeyboy2007
          • Mar 2013
          • 745
          • Scotland
          funnily enought it was the Q6600 quad i was putting in the system, came out a running Acer (my old system) with 4GB RAM also
          • Kiriakos GR
            Banned
            • May 2012
            • 940
            • Greece
            There is speaker pins to hook a speaker plug.
            Possibly you do not have any clue of what you are doing there, this board is relatively fresh and comes with three years warranty.
            You better test and another PSU with it, possibly your old one collapsed by trying to power the quad CPU.
            • Mikeyboy2007
              • Mar 2013
              • 745
              • Scotland
              tried anther 2 PSUs with it but no luck
              • Kiriakos GR
                Banned
                • May 2012
                • 940
                • Greece
                In this case give a beer to @RJARRRPCGP he guessed right.
                • c_hegge
                  • Sep 2009
                  • 5219
                  Either you damaged the socket, or it's just an ASUS motherboard doing what they do best - die for no obvious reason.
                  • Topcat
                    The Boss Stooge
                    • Oct 2003
                    • 16958
                    This. I've seen that happen so many times with Asus hardware.
                    <--- Badcaps.net Founder
                    Badcaps.net Services:
                    Motherboard Repair Services
                    http://folding.stanford.edu/
                    Team : 49813
                    Join in!!
                    Team Stats
                    • RJARRRPCGP
                      • Jul 2004
                      • 6304
                      I heard this is the most likely to happen on A7N8X boards. Because of an nForce 2 flaw that causes BIOS corruption.
                      But, even with an nForce 2, that's mostly unlikely unless OC'ing the FSB a major amount.
                      Unstable FSB is the most likely cause on an nForce 2 board that's been working properly until recently.
                      And more likely to occur on an A7N8X version 1x.
                      One of the message boards I went to had folks talking about A7N8X boards dying often and it seemed that a lot of them were 1.04s.
                      (Good chance that was back in 2003)
                      Arc A770 16 GB
                      • c_hegge
                        • Sep 2009
                        • 5219
                        It happens on all Asus boards from the last several years. Some of the higher end ones might be OK, but in general, Asus motherboards are low quality junk.
                        • RJARRRPCGP
                          • Jul 2004
                          • 6304
                          The P5Q series is a good series, so I don't expect it to be bottom end.
                          (At least many of them.)
                          Arc A770 16 GB
                          • Kiriakos GR
                            Banned
                            • May 2012
                            • 940
                            • Greece
                            From my set of experiences I am aware that most INTEL based boards are hard to die.
                            The guide lines regarding PCB design are identical.
                            Regarding quality of parts? I would not worry if the manufactures have such a faith to offer three to five years warranty (P4C800-E).
                            Actually one shorted USB stick it did manage to damage my P4C800-E, and I did got a working refurbished, four months before the five years warranty expires.
                            About motherboards made in the last two years, I have no experiences, even so what sounds as reasonable to me, is that in every comparison it is more reasonable to use just the model name and not the manufacturer name.
                            By my book, the successfully made models are worthy for admiration.
                            • tmiha71
                              • Apr 2010
                              • 130
                              ROFL.
                              It's obvious, your mobo killed that poor USB flash memory...
