Zotac 2080ti low 1V8 Rail
  • Nick868
    • Oct 2023
    • 17
    • Italy
    Hello
    I've got a zotac 2080ti with 1v8 missing, found the problem and changed U3 buck converter, C70, C81, C75, C82 and R32 with the schematic value. Now i start the gpu and i've 1,2V instead of 1,8V. I think that voltage is too low, what can i check??
  • прямо
    • Sep 2022
    • 261
    • Indonesia
    First of all, is the Zotac using the same buck converter chip GS9216?
    If it is, you should remove R33 (12.7K 1%) which is part of the feedback network that sets the adjustable output voltage to 1.8V, and check its resistance value.
    You may also want to make sure that the R32 you replaced has the correct resistance value and tolerance (10K 1%)
    • Nick868
      • Oct 2023
      • 17
      • Italy
      Yes, i've bought same chip on Aliexpress.
      R33 measures 12,8 on the board without R32, should i remove to check better??
      R32 it's 10K 1%.
      • прямо
        • Sep 2022
        • 261
        • Indonesia
        R32 it's 10K 1%.
        No that's not necessary. 12.8K is close enough.
        What about VIN, is the chip getting the correct voltage?
        Also may want to check R35 (100R 1%), maybe its resistance has gone up.
        • Nick868
          • Oct 2023
          • 17
          • Italy
          VIN it's 12V.
          R35 it's 1.2 ohm mounted on board. Maybe it's this one?
          • прямо
            • Sep 2022
            • 261
            • Indonesia
            Try removing that and measure it outside the circuit.
            On a side note, I don't have the same schematic.
            Mine is MSI, and R33 has a different value. 2.55K instead of 12.7K.
            The chip is also GS9216.
            • Nick868
              • Oct 2023
              • 17
              • Italy
              It's perfect, 100 ohm.
              Well i've another schematic where R32 it's 499ohm and R33 1K. I don't know how many versions there are.
              • прямо
                • Sep 2022
                • 261
                • Indonesia
                Perhaps you can temporarily remove R33 and solder jumper wires from its pads to a 20K or a 50K multi-turn trim pot.
                Adjust the trim pot to 12.7K first, then power up the card.
                Then slowly adjust the trim pot again until you get 1V8 at the output.
                Write down the adjusted resistance for R33, so you can replace the trim pot with a resistor.
                I know that this is kind of a "hack" than a proper problem solving, but hey, sometimes you gotta do what you gotta do to make it work
                • Nick868
                  • Oct 2023
                  • 17
                  • Italy
                  I just removed R33 and it's 10K
                  • прямо
                    • Sep 2022
                    • 261
                    • Indonesia
                    Well, I guess you found your problem.
                    • Nick868
                      • Oct 2023
                      • 17
                      • Italy
                      I've measured voltage on FB both on U3 and U4, and both are on 0.59V. Are these values correct??
                      • прямо
                        прямо commented
                        Editing a comment
                        Yeah it is. Schematic says the Vref is 0.6V, and that's exactly what you're getting.
                        R33 being 10K is definitely the wrong value, because:
                        Vout = Vref x (1 + R33/R34)
                        Vout = 0.6 x (1 + 10/10)
                        Vout = 0.6 x 2 = 1.2
                        So if you want it to output 1.8V, you have to change R33 to 20K.
                        Vout = 0.6 x (1 + 20/10)
                        Vout = 0.6 x 3 = 1.8
                    • McWhitePink
                      • Apr 2023
                      • 103
                      likely the gpu core is dead if you have a short on 1.8V
                      • Nick868
                        • Oct 2023
                        • 17
                        • Italy
                        I don't think so because the short was only on C82. I've to change R33 and try to power on. With 1.2V the GPU start and the core Is warm, but voltage Is too low and the GPU Is not detected.
                        • McWhitePink
                          • Apr 2023
                          • 103
                          1.8V is also powering the VRAM, see if you can find our if any of the VRAM is damaged. better to have a thermal camera for this job.
                          • Nick868
                            • Oct 2023
                            • 17
                            • Italy
                            So i got it finally!!
                            The R33 resistor was too low, i try to put a 12.7K resistor but the voltage was low, about 1.3V. So i put a 20K resistor, voltage was about 1.78V, so i reassembled the gpu and mounted it. Now it seems working and i'm testing!!
                            Thank you all, especially прямо​!!!
                            • прямо
                              прямо commented
                              Editing a comment
                              No worries. Glad to know you got it working
                          • Nagy Daniel
                            Lowest possible resistance on laptop motherboard rail - Guide Table request
                            by Nagy Daniel
                            Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                            I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                            I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                            So, I generated a table with AI so I can...
                            03-04-2025, 08:24 AM
                          • Grucha98
                            Zotac gtx 1060 3gb missing one rail
                            by Grucha98
                            Hello everyone, i have zotac gtx 1060 3gb, and it has missing one rail. I think its 1v but I'm not sure. This rail has 34 Ohms, but after test on on my testbench, it drops to 2ohm, after some time it back to 34 Ohms. Next to this coil is up1727q. And there are 3,3 on vin pin and 5v on vdd pin. I changed this chip with another one but it didnt help. When i tried Short circuit test, core didnt heat up so maybe its still alive. I dont have thermal camera :/. I dont have boardview and schemstic for this GPU too. What should i check next? Or maybe its just dead core?
                            04-11-2024, 08:09 AM
                          • jm1234
                            Reolink RLC-410-5MP - buck convertor
                            by jm1234
                            it's a PoE camera and it stopped working. Using thermal image I identified failing component U22 marked as 16AF which seems to be buck convertor TI https://www.alldatasheet.net/datashe...62569DBVR.html. I took it out and It is inteed shorted on the output. However, after I took it out, the resistance between the output pads (on the board) still shows 190ohm, is that bit low?
                            Another issue is, seems to me I must be missing one of the tiny resistors R810 that should make up the voltage devider for the buck convertor. Honestly I did this months ago, I cannot...
                            07-14-2025, 04:30 AM
                          • Victor Moreira Silva
                            Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                            by Victor Moreira Silva
                            I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                            Well, my decice specs are the following:
                            Model: Acer Nitro 5 AN517-54-55T5
                            CPU: Intel Core i5-11400H
                            GPU: NVIDIA GeForce GTX 1650
                            Motherboard: GH51G LA-L181P Rev:1c
                            The symptom:
                            When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                            05-26-2025, 10:49 AM
                          • bimole
                            Weird behavior on 3.3V rail of a CORSAIR CX600
                            by bimole
                            A colleague gave me an apparently ill CORSAIR CX600.
                            He told me that he heard a banging noise, and smelt the magic smoke.
                            After tearing down the PSU, no burnt component, everything seems OK, but the PSU often refuses to stay ON. When shorting PS_ON to GND, the fan spins a bit a finally stops. No output voltages.
                            I tried to treat some apparently bad solder joins and finally it seems to work OK... on the 12V and 5V rails!
                            It's another story on the 3.3V rail...
                            I have some devices to test deeply PSUs (scope, AC source, electronic load)...
                            02-13-2025, 04:49 AM
