ASRock 775VM800 bad caps
  • Half-Saint
    • Jan 2010
    • 213
    • Slovenia
    I was given this board to see, if it can be saved. There is one obviously swollen cap rated 3300uF 6.3V.
    The problem is that the motherboard doesn't power on - it's dead as a brick. I'm not sure recapping it would help. What do you guys think?
  • Half-Saint
    • Jan 2010
    • 213
    • Slovenia
    Re: ASRock 775VM800 bad caps
    I did a CMOS reset and the system will turn on for a second but then just power off. After trying this, I decided to replace all six 3300uF caps but the result is the same. CPU fan starts turning for a second then the system shuts off.
    What now?
    • Half-Saint
      • Jan 2010
      • 213
      • Slovenia
      Well, no help from here...
      I also replaced four 1200uF 16V caps that looked good on the outside but it didn't do anything so I trashed the board.
      • mariushm
        • May 2011
        • 3799
        What do you expect us to say... guess something out of thin air?
        Post pictures of the board, as clear as possible, maybe we spot something you missed.
        Why did the capacitors go bad? Go to the source.. check the power supply... maybe the power supply is bad and no longer provides good enough power.
        What capacitors did you use? Maybe you used poor quality or unsuitable capacitors, you can't use any brand of capacitors to replace existing ones.
        Pictures... Pictures... Pictures... Pictures... Pictures... Pictures... Pictures... Pictures...
        • Half-Saint
          • Jan 2010
          • 213
          • Slovenia
          I used equal value Samxon caps purchased from badacps a while ago.
          I have no idea why the caps went bad since the motherboard was given to me and I don't have the power supply the original owner was using.
          I decided not to waste any more time on this board since it's an old socket 462 board.
          • heavyice
            • Nov 2013
            • 19
            • India
            Check for shorting and probably could be due to bad MOSFET near the CPU.
              by momaka
              03-12-2025, 03:42 PM
            • eryjus
              by eryjus
              05-10-2023, 11:21 AM
            • Paxman_Swede
              by Paxman_Swede
              Hello!
              01-14-2025, 09:51 AM
            • BigTroll
              Asrock DeskMeet return of the bad caps
              by BigTroll
              I have had good luck with asrock products but with that said I ordered a DeskMeet X300 to use up some other components I had laying around Ryzen 3600 GTX 1060. it comes with a 500w power supply built by CWT.
              I thought CWT would use good components but no the primary cap was ChengX and the secondary had lots of chengx and JunFu caps. hope it lasts awhile. I do have a 450w SFX silverstone with teapos on the secondary I could replace it with.
              10-14-2023, 11:57 AM
            • captain150
              by captain150
              03-16-2025, 07:34 PM
