Foxconn WinFast 6100K8MA recapping advice
  • TheSolarShed
    • Apr 2012
    • 19
    • South Africa
    I have a WinFast 6100K8MA motherboard about which I'd like some advice regarding the capacitors. The list of existing caps are as follows:
    5x 3300uF 6.3v OST RLX
    4x 1500uF 16v UCC KZG
    2x 1000uF 10v Teapo SEK
    8x 1000uF 6.3v Teapo SEK
    9x 1000uF 6.3v OST RLX
    1x 470uF 16v Teapo SEK
    4x 100uF 16v Teapo SEK
    Firstly, the two 10v Teapos only have 5v across them. So they can be grouped under the same capacitors as the 1000uF 6.3v Teapo caps, right?
    Secondly, is there a difference between the OST and Teapo 1000uF caps? I know there is in spec, obviously. But what I mean is: Do you think there is a difference in how they have been used, or do you think they just mixed the two randomly? They seem to be general-purpose bypass caps dotted around the board. Can I replace all the 1000uF 6.3v caps with OST RLX equivalents (since they are the higher spec of the two caps)?
    Thirdly, the replacements for which I have settled are:
    Original: 3300uF 6.3v OST RLX 2780mA 14mOhm
    Replacement: 3300uF 6.3v Nichicon HM 2800mA 12mOhm
    Original: 1500uF 16v UCC KZG 2550mA 13mOhm
    Replacement: 1500uF 6.3v Nichicon HN 2900mA 10mOhm
    Original: 1000uF 6.3v OST RLX 1540mA 34mOhm
    Replacement: 1000uF 6.3v Nichicon HM 1540mA 25mOhm
    Original: 470uF 16v Teapo SEK 310mA ??mOhm
    Replacement: 470uF 16v Rubycon YXG 840mA 87mOhm
    Original: 100uF 16v Teapo SEK 110mA ??mOhm
    Replacement: 120uF 16v Rubycon YXG 340mA 220mOhm
    Do you agree with my choices? Pretty much just looking for reassurance. Though the last two replacements are complete thumb-suck choices.
    Thanks,
    TheSolarShed
    Project CapRep
    Good cap replacement finder
    2354 caps in database so far
  • c_hegge
    • Sep 2009
    • 5219
    Re: Foxconn WinFast 6100K8MA recapping advice
    Those should all be just fine as replacement caps. As for those 1000uF 10V and 6.3V Teapos, they could also be replaced with the Nich HMs you had in mind to replace the OST 1000uF caps.
    • iMic
      IBM NetVista Pentium III - USI Motherboard w/ Teapo SC
      by iMic
      Hi folks,
      I have a couple of IBM NetVista desktop computers from around 2000-2001. They have Universal Scientific Industrial (USI) Pro286i motherboards, 733MHz Pentium III processors, and a whole bunch of bad Teapo capacitors. One board has visibly bad and venting capacitors, while the other doesn't look too bad so far.
      The board with venting caps works fine, while the good looking board occasionally refuses to power on unless it's left for about 30 seconds after connecting the power - even with a known good power supply. (I am however aware I'll need to check the PSU...
      11-29-2023, 06:44 AM
    • Green Probe
      Mosfet Advice
      by Green Probe
      Hi, Im looking to replace some EMP21N03 mosfets on an Alienware motherboard, but I'm having trouble finding a legit supplier. The ones that are available from China have pictures with the engraved logo looking very scratchy and sketchy. Nobody in the US sells them. I'm trying to find a compatible mosfet, but I'm not well versed enough to be confident im making the right choice. Does anyone have a suggestion or advice that could help me find the right mosfet? Thanks!
      05-22-2025, 10:49 AM
    • user234
      Gigabyte Eagle 3060 Ti - Boardview / Advice request please
      by user234
      Recently installed a new motherboard but during the process I seemed to have damaged my Gigabyte Eagle 3060 Ti card.
      My motherboard ROG STRIX B550-A is detecting an issue with the VGA (light ON)
      I have attached 2 photo's of my GPU board, one above and the other is what I believe to be the 5V - as you can see, this has visual damage so looks suspicious to me.
      If I replace this part what are the odds this will resolve the issue? - any additional information on where to source the parts would be much apricated too!
      This is...
      05-10-2025, 04:25 AM
    • beal
      Bios MainBoard FoxConn CLO430
      by beal
      hi
      Please Bios MainBoard Foxconn CLO430 Rev A01
      thanks
      post moved..
      04-26-2025, 03:28 AM
    • artvandalai
      Advice on rewiring this stepup transformer?
      by artvandalai
      I bought this Chinese made step up transformer to run some 220v appliances. Some of the wires were brittle and broke off. I attempted to improve some of the wiring with spade terminals and heatshrink tubing as the wires were just soldered straight to the connectors. Any advice on how to rewire the broken wires on this step up transformer? I'm unsure how to go about rewiring this to a better safe working condition.
      01-14-2025, 01:00 AM
