Dell Precision 470
  • smason
    • 1652
    Dell Precision 470
    A friend of mine gave me his Precision 470 to fix.
    It's a dual Xeon, in use as a Linux server.
    Symptom, power LED is yellow.
    I opened it up, and there are several bloated caps on the motherboard.
    Mostly the 6.3v ones. Some Nichicon HNM series and a couple of Rubycons.
    All of the Matsushita FL and the 3.3v ones near the procs look fine.
    I'm hoping the power supply is fine, and it's just these caps.
    Tempted to put in some Panny FM and FCs, as I have stock, but I guess I should look up the specs, as it's more critical than the monitors I'm used to using Pannys in.
  • smason
    • 1652
    Re: Dell Precision 470
    Update 1:
    looked at the specs, pannys were a bit lacking in the ripple dept. so I decided to go with Nichicons, added to the order I was about to place anyway.
    • smason
      • 1652
      Wow, I forgot how much I hate working on motherboards.
      Intersting, the 2 bloated Rubycons off by themselves were very bad 1500uf measured 8uf and 58ohms ESR.
      The 3 Nichicons grouped together, 1 bloated - the bloated one was bad, the other 2 measured almost perfect.
      Will re-assemble tomorrow and test. <crossing fingers>
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5042
        • US
        remember dells commonly have the positive side marked
        • smason
          • 1652
          Yeah, I just barely noticed that in time.
          • smason
            • 1652
            Got it all back together and.... same problem.
            Time to look at the power supply.
            • smason
              • 1652
              OK, getting back to this, spent a bit of quality time on it tonight.
              Was able to get the power supply to fire up by pulling PS_ON to gnd.
              It measures good on all outputs, with a very light load.
              So a question. The system has a yellow indicator on the power switch BEFORE you try to turn it on. My understanding is the only thing it sees from the power supply at this stage is 5Vstandby (which is fine, and the motherboard LED is green) and the PS_ON line, which by the way is only 4.8v unloaded.
              What would the motherboard be complaining about, the PS_ON voltage being low?
              • smason
                • 1652
                Another hour wasted, still dunno wtf is up.
                Following the logic of my last post (motherboard only gets 5vstby and ps_on in powered off mode, and the slightly low 4.8v of the ps_on might be doing it,
                I connected the power supply, minus the ps_on line, and fed the motherboard the ps_on line from a good power supply, yes with proper grounds etc. Power button still yellow.
                disconnected the second supply, and grounded the ps_on line of the main supply, and the supply powers up. CPU coolers come on, but no boot (I don't expect it to boot, as there's probably some more power on logic needed, and it still "thinks" there's a fault <yellow power button>
                I measured the 5V-stby it's 5v. So I don't know what the motherboard thinks is wrong.
                So now I'm leaning toward it being a motherboard problem.
                • Pentium4
                  CapXon Be Gone
                  • Sep 2011
                  • 3741
                  Are you getting a screen, POST, etc? Or is it just a black screen?
                  • smason
                    • 1652
                    Nothing. It doesn't seem to try to post when I force PS_ON on the PS, but I suspect there's other logic required to get a motherboard to start than just having the supply come on.
                    • Pentium4
                      CapXon Be Gone
                      • Sep 2011
                      • 3741
                      Yeah. I had a dead server board with some bulged Sanyo caps on it. When I got really close to it, I could smell one of the little IC's. It smelled really burnt, but only when I got my nose really close to it. I'm guessing that is what killed the Sanyo caps. This server would not POST either
                      • smason
                        • 1652
                        Now that I think of it, the owner mentioned having some usb issues. Tomorrow I'll check the USB ports and circuitry, maybe something there is pulling a voltage down.
                        • smason
                          • 1652
                          Thinking this through a bit more, when you connect AC power to many Dell models (when they're working properly) they DO do a brief power on (fans lights etc.) so it may indeed be looking for some response from something other than just 5VStby.
                          • Uranium-235
                            Comrade Glimmer
                            • Aug 2007
                            • 5042
                            • US
                            yeah i've noticed that too before. But they usually never 'yellow' button during this activity. USB problems? Sounds to me like the chipset is going bad. There is a chance that the bloated caps over-volted the southbridge, northbridge, or CPU (which BTW, have you tried replacing that?)
                            wait, cut that, its a fucking xeon (..does research..) yeah 604 Xeon chips
                            funny, my poweredge 1800 (also dual Xeon 604 /w DDR2 3200) has about the same specs, nothing but rubycons on this board. fucking dell cheapening out
                            • Nathan
                              • Jul 2010
                              What it took to fix our Dell 470 motherboard.
                              I just had a couple days of fun repairing a Dell Precision 470 motherboard and thought I would share what we found with you nice people. (A little late..sorry)
                              Short version: In my case, the failed capacitors killed the Power Controller IC (IC5) on the motherboard.
                              Initial symptoms:
                              The system had a Amber lite on the front panel. The system would not power on at all. When the chassis was opened, we noted the "Aux Power" (amber) and "STR_LED" (green) were illuminated any time the AC power cord was plugged in to the power suply.
                              Visual inspection revealevd that C149 and C150 had vented.
                              The power supply was eliminated as possible failure with known good Power supply.
                              Corrective action:
                              ALL electrolytic capacitors were replaced. System still had the same problem.
                              No capacitors measured unusally high ESR or out of tolerance.(except C149 and C150)
                              We discovered that the Gate on one of the MOSFETs on the motherboard was shorted directly to GND.
                              The short was eventually traced back to the PWM/triple linear regulator IC on the motherboard. (IC5) Pin 10 (LGATE) was shorted to Pin 9 (Gnd) The part number for this component is HIP6521. This was ordered from Digikey and the IC was replaced. This repaired the motherboard to operational status.
                              FYI- Observed Normal operation = When AC power is applied the fans spin and The STR_LED illuminate for a moment and then stop until the power button is pressed.
                              Well wasn't that fun....
                              Regards,
                              • smason
                                • 1652
                                Re: What it took to fix our Dell 470 motherboard.
                                Originally posted by Nathan
                                I just had a couple days of fun repairing a Dell Precision 470 motherboard and thought I would share what we found with you nice people. (A little late..sorry),
                                Hi, welcome to Badcaps. Not too late, I haven't scrapped it yet.
                                Thanks for the info! I'll definitely check that out when I get a minute.
                                Been a busy 2 weeks here, with flooding, no power for a week at work, then a record humidity day that caused an A/C unit to belch water into a server rack.
                                Totally fried a Dell PowerEdge 1950 (will post a thread with crispy photos later)
                                • smason
                                  • 1652
                                  Well, it's not that chip but it may be something in the neighborhood.
                                  Pin 6 measures 1.8 ohms to ground. Pulled the chip, chip measures ok, pin 6 still 1.8ohms to gnd on the board. Pulled the FET that's connected to pin 6, same.
                                  There are 2 bypass caps and 2 electrolytics all in parallel that all read 1.8 ohms. I pulled one ceramic, it's fine, the other is on the top side between the electros, so I'll need to pull them all to check the ceramic. Or it could be anything else
                                  • Nathan
                                    • Jul 2010
                                    F.W.I.W.- I measure ~11.2 ohms from pin 6 "PHASE" to Pin 9 "PGND" on IC5 (Intersil- HIP6521) on a working 470 motherboard.
                                    (with or without CPU installed)
                                    Last edited by Nathan; 07-08-2013, 12:24 PM. Reason: added with or without CPU part
                                    • smason
                                      • 1652
                                      Thanks, that's helpful.
                                      • Per Hansson
                                        • Jul 2005
                                        • 5895
                                        • Sweden
                                        If you want i have a recapped 470 mobo that I don't use, drop me a PM if you are interested.
                                        Photots of it here: https://www.badcaps.net/forum/showthread.php?t=5974
                                          DELL Precision T3420 Precision E3-1220V5 Specification for Upgrade or Repair
                                          This specification for the DELL Precision T3420 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Precision T3420 boardview and Precision T3420 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                                          09-12-2024, 03:44 PM
                                          DELL Precision T5820 Precision 5000 i9-9920X Specification for Upgrade or Repair
                                          This specification for the DELL Precision T5820 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Precision T5820 boardview and Precision T5820 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                                          DELL Precision T3630 Precision 3000 E-2174G Specification for Upgrade or Repair
                                          This specification for the DELL Precision T3630 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Precision T3630 boardview and Precision T3630 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                                          DELL Precision 3630 Precision E-2274G Specification for Upgrade or Repair
                                          This specification for the DELL Precision 3630 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Precision 3630 boardview and Precision 3630 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          DELL Precision 3620 Precision i7-6700 Specification for Upgrade or Repair
                                          This specification for the DELL Precision 3620 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Precision 3620 boardview and Precision 3620 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
