Dell Sx270
  • mkaleu
    • Dec 2006
    Dell Sx270
    also the Dell SX270 ist infected by those bad caps. I am lucky, because DELL changed all my 4 Motherboards free of charge (2 where out of guarantee and all where used and bought from Ebay.) That is service!!!!!
    Regards Mike
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
  • F R 2568
    Dell Latitude 5420 does not start (no post) need help to find the reason why
    by F R 2568
    Hello all,
    this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
    I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
    If the laptop is only connected to the AC adapter (battery removed):
    When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
    The power/battery...
    01-08-2025, 05:45 AM
  • diamon
    Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
    by diamon
    I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
    Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
    Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
    Pictures of these boards:
    Dell Latitude 5520 https://www.ebay.com/itm/256052956663
    Dell Latitude 5530 https://www.ebay.com/itm/125844181534
    Dell...
    02-28-2024, 12:51 PM
  • master3112
    by master3112
    07-29-2025, 01:55 PM
  • OntarioTL
    Dell 5410 greyed out BT
    by OntarioTL
    Well I've learned something new today. Of all the Dell laptops I've come across I have never seen bluetooth greyed out, and only to learn this is during the build from Dell factory. I've tried to pull the original BIOS and fix with another dell with the same issue on the forums, however the original was not recovered from the forum upgrade so I cannot do a comparison to attempt the fix on my own.
    If someone could help me out with this unit and I'll try the next one as so far I have 2 on my desk with this issue. Thanks in advance!
    Dell Lattitude 5410
    Service Tag...
    07-25-2025, 01:28 PM
