MSI 7950 replacement capacitor
  • Chads
    • May 2013
    Hi all. I'm so glad this forum exists. I know only the basics on components and some of these ratings threw me a little.
    I've got my hands on an MSI 7950 GPU, which has had a capacitor broken off. The ratings are as follows: ULR 16V 270uF BP
    Am I right in thinking this would be a suitable replacement? What exactly does the ULR stand for?
    The guy I bought it off of also gave me a replacement rated as: FP 25Ad 271 16, which doesn't seem right. Or would it work?
    Help would be hugely appreciated. Thanks.
  • mariushm
    • May 2011
    • 3799
    Re: MSI 7950 replacement capacitor
    ULR is the series name.
    It's a series of capacitors manufactured by Samxon, here's the datasheet (temporary ftp location) :
    It's a through hole polymer capacitor optimized for high ripple current and low esr. 271 is 27 x 10^1 = 270uF , 16 is the voltage rating.
    It can be replaced with any capacitor that has at least 5000mA ripple current and at most 13mOhm, as you can determine from the tables in that datasheet.
    So if you go on digikey, just filter by polymers, 270uF , 16v then sort by ripple current and pick what works best for you (check diameter mostly)
    The one you linked to will do. So will these ones:
    http://www.digikey.co.uk/product-det...018-ND/1136108
    http://www.digikey.co.uk/product-det...615-ND/3528476
    http://www.digikey.co.uk/product-det...7-1-ND/3466007
    etc etc
    • Chads
      • May 2013
      Thanks for the reply.
      So if the FP 25Ad 271 16 is in fact 270uF, if the ripple current and esr are suitable, I could use it?
      Or are BP and FP not interchangable (I assume BP is bipolar, not sure about FP)
      • mariushm
        • May 2011
        • 3799
        They're not bipolar, both have a negative sign (band).
        Yes, the FP (Functional Polymer) capacitor should be adequate.
        • MORETTIGIAN
          by MORETTIGIAN
          Title:
          Description:
          Procedure performed:
          - Removed backplate
          - Reapplied thermal compound
          - Reassembled card
          09-18-2025, 12:14 PM
        • artvandalai
          Where can I get compatible capacitor for replacement?
          by artvandalai
          Blew the capacitor on my analytical balance scale using the wrong power adapter. I need help finding a replacement compatible capacitor to buy. Will any 100uf 40v capacitor work as a replacement?
          12-28-2024, 10:15 AM
        • r2digital
          klipsch kda-500 amplifier suitable power supply capacitor replacement ?
          by r2digital
          I have a klipsch kda-500 that would turn on and allow me to get into the web management but it was picking up a lot of noise from audio sources so i decided to replace the smd caps on the power supply along with radial one. Some one was in here before me and they basically burned the bottom side of the traces off for the radial cap but i was able to repair it without any real problem. I thought i did a good job sourcing out replacement caps but apparently not and now i can't get the power supply to turn on it just constantly try's to keep turning on. Attached is a picture of the power supply before...
          04-18-2024, 03:50 PM
        • rwkish
          Discontinued Capacitor looking for Replacement
          by rwkish
          Capacitor has been discontinued (EGXF101ELL331MM20S) all of the replacements I have found have are smaller than 0.709" Dia (18.00mm). I would like to use the same size or at least close to the same size Capacitor. 19mm would be too big as they would touch and not be able to through hole mount. Tia...
          08-18-2024, 06:54 PM
        • Hylax
          Replacement capacitor options please?
          by Hylax
          Hi, I'm super new to this capacitor stuff but I've some basic soldering experience with old cellphones PCBs and headphones. I have this APAQ AR5K 820∆μF 3V Dc Capacitor from a motherboard that I'm looking to replace, photos I've attached. But I'm unable to find a 3V one like I've marked in the spec sheet in red (This is the one currently present in the motherboard). But the 6.3V one I can find (marked in blue) is of similar dimensions but different specs as mentioned in the table. Is it okay to replace it with higher voltage cap, slightly higher ESR, slightly lower ripple current, and double...
          08-09-2024, 11:25 PM
