Abit AI7 - no improvement by better Caps, right?
  • Albatroner
    • Nov 2006
    • 9
    Hello, here I have a Abit Ai7, which will heavily overclocked!
    I know, that Abit equip their boards with good Caps, also at my AI7?
    Please have a look:
    If you need the exact type of a Cap to give a recommendation please let me know.
    Thank you
    Sorry if my English is not 100% correct, but I hope you can understand it.
    Regards
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    Re: Abit AI7 - no improvement by better Caps, right?
    Looks like all Rubycon caps. You'll be good to go there!
    Ludicrous gibs!
    • Albatroner
      • Nov 2006
      • 9
      Ok, I just wanted to go sure
      The same good caps are on my NV8, right? (don´t want to make an extra Fred):
      Thank you
      Regards
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        your AI7 has rubycon MBZ, ZL and YXG
        the NV8 has chemicon PSC polymer on vcore, the best caps of the chemicon range. thats great. also there is rubycon YXG
        you can check the caps here. they are better towards the right.
        https://www.badcaps.net/forum/showth...0984#post10984
        • Albatroner
          • Nov 2006
          • 9
          ok, thanks!
          I love Abit
          They mostly have the best Caps, right?
          Regards
          Thank you
          Regards
          • gonzo0815
            • Feb 2006
            • 1600
            Yeap, the newer boards are good. Any way, at that price tag i think they should deliver something in that area of quality. I have build a rig with an Abit A8N-SLI and even the availiable sttings and overall quality was very ver yhigh, the system had some quirks. I got it stable, after loading a new bios wich addressed some memory related problems and the AMD DC fix. From that a board i have`t expected sutch problems. Those HEatpipe NB & SB cooler is IMHO not a very good cooling solution.
            In the past, even Abit sold bad caps.
            • eryjus
              by eryjus
              05-10-2023, 11:21 AM
            • Paxman_Swede
              by Paxman_Swede
              Hello!
              01-14-2025, 09:51 AM
            • captain150
              by captain150
              03-16-2025, 07:34 PM
            • Foetuss
              Gigabyte GA-6OXT :: caps question
              by Foetuss
              Good evening
              I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
              Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
              But I was also suprised about the bigger boys, which are 330µF 25V.
              Could it be they used 25V caps because they were cheaper / available at that time?...
              02-11-2025, 12:22 PM
            • madscientist750
              Replacing electrolytic caps by solid caps on old motherboards
              by madscientist750
              I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
              I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
              I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
              10-19-2025, 06:10 AM
