Traces Lengths and OCeability
  • Calchaqui
    • Oct 2005
    • 112
    Hi, since 1998 OC days, I've always suspected that traces lenghts affect voltage cleanness. I've got 2 mobo differ. revition, one has the ATX power connector in the middle of the VRM CPU zone, and the other one to the right of the dimm-slots. First one OC very good CPU, but is unstable even at stock with all-4-dimm filled at aggresive timming 2-2-2. The other one is very stable at 2-2-2 , but not so good at CPU OC. Could it be because of the shorter distance between ATX power and DIMM regulator zone?
    I LOVE WWW.BADCAPS.NET
  • howardc64
    Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
    by howardc64
    Problem
    Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
    Model & Board Pics
    Conflicting Spec
    Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
    https://www.shopjimmy.com/vizio-gj-2k1...
    10-10-2024, 01:16 PM
  • siccfix
    HP Omen 15-ek0013dx - Odd 4-Zone RGB Issue, Replacing Entire Keydeck Didn't Fix It
    by siccfix
    Replaced the keyboard+LED backlight+topdeck unit with a completely assembled aftermarket part a few months ago due to failing keys (Spacebar, X, R; seems to be a common issue for 2020 model). I thought this would also fix my RGB backlight issue but the problem remains, actually it got worse, so it has to be a failing part on the mobo itself. The middle RGB zone can no longer light up blue and is instead stuck on green, even if all kb backlight is turned off that zone stays lit..
    Does anyone know what part number the IC labeled UI3 is? Seems to be some kind of LED controller chip....
    04-24-2025, 08:54 AM
  • jeremy96
    PS4 Power Button Traces
    by jeremy96
    I recently bought a used PS4 and discovered that the power button is broken. Upon closer inspection, I found that the traces for the power button on the PCB are damaged and torn.
    Does anyone know where these traces lead or have any advice on how to repair them?
    Thanks in advance for your help!​...
    05-26-2024, 05:01 AM
  • foshland
    DELL XPS 9560 Burned zone need photo please
    by foshland
    Hi to all, I have a XPS 9560 with some faults, im working on it for fun, I have a "burned" zone I need to dremel but afterwards ill need a photo of the zone for rebuilding as far as I can, I have the schematics and the boardview but will like a photo, if some of you can get any so I see the traces will be cool.
    It was some kind of lucky that the zone had not too much components, so I think I can deal with it.
    Its under the zone where PC308 PC309 and PC337 is located, next to PU300
    Thanks a lot for all and "pray" for me ...
    04-21-2022, 07:33 PM
  • computerden
    PS5 EDM-020 Caps on encoder to apu traces
    by computerden
    Hey,
    Got a ps5 here no display, either white light or plusing blue. no display in safemode.
    but there are missing caps after the encoder on the traces to the apu
    there was one i was able to find half attatched and got it back on,
    what would i replace these with?
    is there any compatible ones i could nab off a ps4?...
    05-19-2023, 04:58 AM
