asus p5ql pro 12v atx problem
  • bloodline
    • Dec 2012
    • 6
    • spain
    I have a asus p5ql pro motherboard every time I connect the 12v atx power supply to the motherboard it will not boot with out the 4pin 12v atx power supply connected the fans and hard drives will power up. I have tried another power supply so I can rule that out of the problem any help would be great
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: asus p5ql pro 12v atx problem
    Not good! Try again with the board lifted away from metallic surfaces. First, clear the CMOS.
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      This almost always means shorted MOSFETs in the CPU VRM. Test them for shorts with your digital multimeter and replace as needed.
      A working TV? How boring!
      • lazaro.089
        Asus Zephyrus M16 / GU603ZW problem
        by lazaro.089
        Full name/ Model: Asus Zephyrus M16 / GU603ZW-M16.I93070T
        CPU: Core i9-12900H
        Onboard 8GB DDR5 4xMT60B1G16HC-48B:A
        Problem: This laptop was brought to the shop with the board already meddled with. Last technician (maybe without the right tools) removed an electrolytic capacitor (PCE9203) sensing resistor (PRS9801) and probably flashed both BIOS (U2802) and VBIOS(U7802).
        The laptop's behavior is: When connected, it tries to power up. CPU powers on, and (allegedly) the power sequence finishes and goes to S0 (PLT_RST = 3.3V). It consumes 600mA, ramps up to 1.100 A and...
        08-26-2025, 06:33 PM
        03-31-2024, 02:12 PM
      • AtelierRepa
        ASUS X712JA problem
        by AtelierRepa
        I have a problem with the bios, let me explain.
        With BIOS 1, the pc takes +- 30 seconds to display the ASUS logo (black screen) and to boot.
        I did a clear ME, my black screen problem for 30 seconds at boot is solved, it gives me directly the display and boots quickly.
        My problem is that now, once the charger is plugged in and I put a slight load on the processor, it bogs down to 0.39GHz...
        The only solution is to unplug the charger to get the cpu back up to speed. But as soon as I plug in the charger, it goes straight back down....
        06-15-2024, 04:33 AM
      • pkslowk
        Debug Card Error Code and Solution
        by pkslowk
        Sr. Motherboard Debug Error Code Solution
        1 Intel 845 E9 Bios Related Problem
        2 Intel 845 D4 CPU Socket Related problem
        3 Intel 845 37 Bios Related Problem
        4 Intel 845 7C Bios Related Problem
        5 Intel 945GCPE 34 Bios Related Problem
        6 Gigabyte 845 2 Ram Related Problem
        7 IBM Server A6 A7 Ram Mismatch Problem
        8 Asus 845 29 CPU Related Problem
        9 Lenovo I946 97 C-Mos Jumper related
        10 Gigabyte 845 A0 CPU Related Problem
        11 Asrock G31M-VS D7 Bios Related Problem
        12 Compaq 845 BD-70G B0 CPU Socket Related problem...
        01-28-2021, 12:51 PM
      • greg1985
        Asus dabkxmb18b0 rev.b bios problem
        by greg1985
        Hi. I bought a damaged Asus motherboard, model dabkxmb18b0 rev.b. The problem with the motherboard was a faulty processor.
        I replaced the processor, but it arrived without a BIOS chip. I found one post on the forum, but my problem is
        I don't know which chip to program, and I don't have a schematic. Does anyone know which BIOS chip models are compatible with this motherboard? If so, please let me know. Thanks.
        10-20-2025, 11:34 AM
