Re-capping eVGA GeForce 7600
  • n-CHRIS-b
    • Dec 2012
    • 5
    As part of learning to solder, I am going to replace blown capacitors on my mom's motherboard. I've already ordered the caps kit for the MCP61PM-HM 1.0B (motherboard by ECS for HP). To assist with the learning curve, the last step before touching her MOBO is to replace blown caps on the AGP video card mentioned in the title, then testing my work in a different computer. I've done my research, including reading here, and this card was put together with only Sacon caps(!) at 1500uF 6.3V, 470uF 16V, and 1000uF 6.3V.
    I respect Topcat and this site, but it was frustrating that I never got an email reply from him about what I should replace these with. So I took a chance and ordered Nichicon caps that are electrically compatible with the ones that need to be replaced. However, the caps I received are physically different from what's on the card; will this be a problem?
    Also, the caps on the video card have a blue "stripe"--for lack of a better word--on the top, whose side and orientation matches the white stripe in the circles they "sit" in. I assume this means the polarity is on the blue/white side, which is somewhat confusing, because a "+" is on the other side. Do I guess correctly?
    I can provide pics if you need them.
    Thx for your help
    P. S. I can't tell if the card is a GS or GT, partly because I threw away the box.
  • mockingbird
    • Dec 2008
    • 5484
    Re: Re-capping eVGA GeForce 7600
    What series are the Nichicon caps you ordered to replace the Sacon caps?
    • c_hegge
      • Sep 2009
      • 5219
      Assuming you got the same uF and voltage as the originals, you will be fine. Topcat only sells HM, HN and HZ series, all of which are fine for this application.
      • n-CHRIS-b
        • Dec 2012
        • 5
        HN for the 470's, HN and HZ for the 1000's, and HZ for the 1500's. I couldn't tell if I needed HN or HZ for the 1000's, so I got both.
        • n-CHRIS-b
          • Dec 2012
          • 5
          I went out of my way to make sure they matched. That is partly why I ask about their physical size. I don't want to damage the board.
          • c_hegge
            • Sep 2009
            • 5219
            Their physical size shouldn't be a problem. I'm assuming you are saying the diameter is different. Most cards will be screened for both 8mm and 10mm caps, and have holes for both, so you can use either. If not, you can mount them 1 or 2 mm off the PCB, which will aleviate the stress on the caps legs, seal and on the PCB pads.
            • n-CHRIS-b
              • Dec 2012
              • 5
              On practice solder kits, I mounted the caps a few mm off the board while I used a heat sink. Even then, the finished product still worked. On the video card, I noticed it has holes for both the 8mm and 10mm caps, so all is not lost. lol
              I actually meant the height is different, but I'm going to assume it makes no difference, since electrical ratings are electrical ratings.
              Above, I think I actually answered my own question about the polarity orientation of the old caps. lol I believe I was overanalyzing about the "+" next to the circles.
              • KeriJane
                Mac Enthusiast
                • Sep 2008
                • 681
                Quality replacement caps are often taller than their "equivalent" cheap OEM ones.
                This isn't a problem unless it's going to hit something like the case or a heatsink.
                A lot of OEM caps are also too narrow for their capacity as well. Like a 10mm⌀ 4700µf/6.3v, no reputable manufacturer offers an "impossible" size. It's better to use a quality cap of lower capacity but equivalent ESR if there is no room for a larger one.
                Polarity markings on the cap itself are universal- The band, stripe or mark indicates Negative (-) as does the short lead on a Radial cap.
                Markings on the board are "almost" universal. Most boards are marked to indicate where Negative is, and you line up the stripe on the cap with the mark on the board.
                But some manufacturers mark them opposite, with a mark for Positive (+)!
                Others use a tiny + sign.
                It's best to look at the board before removing the old cap and see if the markings are standard. If they're not visible, make your own marks or draw a chart.
                A motherboard is a difficult soldering task. They're not just double-sided, they're multi-layered. This makes desoldering the old caps difficult as the heat is wicked away too quickly to melt the solder all the way through.
                Good luck!
                The More You Learn The Less You Know!
                • n-CHRIS-b
                  • Dec 2012
                  • 5
                  Good luck!
                  Ok. Thanks for the pointers on polarity orientation. I know how to interpret those now.
                  The few times I've picked up the motherboard, I figured it would be complicated. Until working with the video card, I had never experienced soldering with such tiny holes. And without totally understanding why, I sort of knew that the motherboard would be an order of magnitude more challenging than the video card. Still, I understood that repairing the video card would be a crucial step on the way to the motherboard.
                  From what I've read, other people have tried--successfully--to solder new, better caps on their motherboards, with success (and with as much experience as I have lol). As with other endeavors, the learning curve is longer for me, out of worry that I'll screw it up, and because it can take a while to get my head inside what I'm doing. Again, that's the reason I choose to repair the video card first--I can learn on a smaller, less intimidating project.
                    EVGA e-GeForce 7600 GS AGP 256MD2 [256-A8-N542-T2] with bad caps - fixed
                    by momaka
                    I did it again – I had to fulfill my inner desire to fix yet another old piece of hardware. This one is actually kind of worthwhile, too – it’s an EVGA e-GeForce 7600 GS AGP video card, model P/N: 256-A8-N542-T2. With the popularity of “retro” PCs from the Win9x to XP era going up, and the diminishing supply of decent AGP cards, it is expected their prices will go up. Or is it? I bought the this video card rather on the cheap side (~$9 USD shipped to my door), because the eBay seller listed it for parts or repair (and correctly noted the bad capacitors.)
                    So, here is the...
                    06-06-2020, 04:39 PM
                    NVIDIA GeForce RTX 3080 / RTX 3090 Schematic & Board View
                    The GeForce RTX 3080 is an enthusiast-class graphics card by NVIDIA, launched on September 1st, 2020. Built on the 8 nm process, and based on the GA102 graphics processor, in its GA102-200-KD-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 3080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The GA102 graphics processor is a large chip with a die area of 628...
                    10-02-2024, 08:52 AM
                    by momaka
                    03-12-2025, 03:42 PM
                    NVIDIA GeForce RTX 2060 / RTX 2070 Schematic & Board View
                    The GeForce RTX 2060 is a performance-segment graphics card by NVIDIA, launched on January 7th, 2019. Built on the 12 nm process, and based on the TU106 graphics processor, in its TU106-200A-KA-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 2060. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The TU106 graphics processor is a large chip with a die area of 445...
                    10-02-2024, 07:51 AM
                    NVIDIA GeForce GTX 950 / GTX 960 Schematic & Board View
                    The GeForce GTX 950 was a mid-range graphics card by NVIDIA, launched on August 20th, 2015. Built on the 28 nm process, and based on the GM206 graphics processor, in its GM206-250-A1 variant, the card supports DirectX 12. This ensures that all modern games will run on GeForce GTX 950. The GM206 graphics processor is an average sized chip with a die area of 228 mm² and 2,940 million transistors. Unlike the fully unlocked GeForce GTX 960, which uses the same GPU but has all 1024 shaders enabled, NVIDIA has disabled some shading...
                    10-01-2024, 01:54 PM
