Asus p5kpl-am epu. Have power but no display Would you Help?
  • lorins_core
    BlackSmith
    • Dec 2012
    • 551
    • Philippines
    I have Asus p5kpl-am epu mother Board. the problem is No Display. I Chage a Memory and Power supply it is the same problem. also i change the Microprocessor. i Double Check the processor, memory and Power supply is Good. i wonder they have problem in Mother board also i try touch the Microprocessor is it not Heat? i used the Old Processor and Try a New Good it is Same not Heat. it find here https://www.badcaps.net/forum/showthread.php?t=18282. but it is a Counter of may Problem... i Need you Help...
    Thank and More Power
  • lorins_core
    BlackSmith
    • Dec 2012
    • 551
    • Philippines
    Re: Asus p5kpl-am epu. Have power but no display Would you Help?
    I Follow Up.. Help Me...
    • lorins_core
      BlackSmith
      • Dec 2012
      • 551
      • Philippines
      Any idea?
      • lorins_core
        BlackSmith
        • Dec 2012
        • 551
        • Philippines
        • DJduck
          • Dec 2012
          • 229
          • Estonia
          Did you check the caps? Cpu power cable? Also your problem might be the cpu. Some boards do not support all the cpus with the same socket. Check the cpu model and then see if your chipset or board is compatible with that cpu. I had the same problem with another asus s775 board, it did not power up with my core 2 duo. Tried it with p4 and it worked nicely. What cpu are you using? Also your northbridge might just be cooked.
          I can put text here?!
          • GLISIT
            by GLISIT
            01-16-2025, 02:29 PM
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • PantherDave
            by PantherDave
            Hi all!
            05-29-2024, 02:01 PM
          • ShadowAi
            ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
            by ShadowAi
            Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
            Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
            After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
            03-15-2024, 10:46 AM
          • meraklinetx
            Asus Z97-a power cycle, no boot no cpu voltage
            by meraklinetx
            Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
            05-10-2023, 06:08 AM
