Ga60XET recapped
  • jakah
    • May 2006
    • 31
    Ga60XET recapped
    I bought this board cheaply from a guy who sold it as defect. He told me it posted, but was unstable.
    The board had four bad GSC caps (3300uF 6,3V), four still good Choyo caps (1200uF 6,3V) and 11 small 330 uF Gluxon caps. I replaced only the GCS and Choyo ones. I didn't mind the Gluxons as they were of such small capacitance.
    As replacement I coulnd't find any fitting caps to buy, so I replaced the four GSC ones with Sanyo 3900uF 6,3V caps found in an old Dell BX board, and the four Choyo ones with a three Sanyos and one Rubycon cap (both 1500uF 6,3V) from a noisy MSI Nforce 2 board I wrote about here a while ago: https://www.badcaps.net/forum/showthread.php?t=2132
    I didn't manage/care to try to fix it, so I took the caps I needed from it, and trashed it.
    Is taking caps from an old board like this OK? I remember reading posts from some of you where you state that this is a bad idea. Why is that?
    Sorry if the pics aren't very good, the recap pic only shows a part of the board. I didn't mind taking more pics as my old lousy camera refuses to work properly sometimes.
    Anyway, the board seems to be running fine after some testing with a 1300 tualatin celeron, so I consider the board stable!
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
  • Dani_2024
    by Dani_2024
    10-28-2024, 05:06 PM
    by momaka
    03-15-2023, 10:17 PM
  • black6host
    Replacement caps for Samson Resolv studio monitor 65A Amp board.
    by black6host
    Good day!
    I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
    I'm going to replace the caps and I'll be the first...
    02-06-2024, 08:22 PM
