EVGA GTX 460 - Bad Caps
  • ameixoeiro
    • Oct 2014
    • 17
    • Portugal
    Re: EVGA GTX 460 - Bad Caps
    hoomanium i'm sorry to ressurect this post but, did you get your card working?
    Thnx
    • Behemot
      • 4845
      • CZ
      I guess. By the way X-CON polymers were somewhat omited though they are of the best…
      • Fast Alpha
        • Feb 2013
        • 245
        • United Kingdom
        got this card a EVGA 750ti SC 2GB. Is this good card ????
        http://www.newegg.com/Product/Produc...82E16814487024
        http://www.hse.gov.uk/pubns/indg305.pdf
        • loopypalm
          • May 2017
          • 4
          • morocco
          hi everyone
          first of all : i'm not good at electronics :XD
          yesterday i was playing in "nier automata" for a long time and i heard an explosion and the PC restart
          it seems to work fine but when i clic on a video or a game it shutdown
          i found that my GTX460 was the problem
          i dissassembly it and found that 5KQ12/270/16V capacitor exploded
          is that cap the only damaged one ? cuz it seems to work fine until i clic on a video
          can i replace it with a 330/16V or 180/16V ?
          any idea would be apreciated ^___^ !
            master hoarder
            • May 2008
            • 12168
            • Bulgaria
            The 330 uF, 16V should do, as long as it is a POLYMER capacitor.
            • loopypalm
              • May 2017
              • 4
              • morocco
              #26
              it worx !
              thank you so much ^^
              but the heat is not normal (i think)
              now it reatch 73 C
              does it means something else is bad ???
              • Per Hansson
                • Jul 2005
                • 5895
                • Sweden
                #27
                What reached 73C?
                The capacitor or the GPU?
                • ChaosLegionnaire
                  HC Overclocker
                  • Jul 2012
                  • 3264
                  • Singapore
                  #28
                  nah the temperature is normal for that gpu. the gtx460 is a mid-high end gpu plus the stock cooler on the evga is crap if its the single fan stock cooler. lots of failed single fan evga gtx460 cards on ebay so no surprises there. btw caps dont explode for a reason. make sure your psu has sufficient wattage to power the power-hungry gtx460 and make sure its not a junk no-name brand psu!
                  • loopypalm
                    • May 2017
                    • 4
                    • morocco
                    #29
                    @Per Hansson
                    the GPU
                    @ChaosLegionnaire
                    i have a good PSU with 650W
                    and my GTX460 is not evga it's AZUS
                    "caps dont explode for a reason"
                    does this means that cap is the only one damaged ???
                    the card is working fine now
                    but i'm worried about a future explosion >w< !
                      master hoarder
                      • May 2008
                      • 12168
                      • Bulgaria
                      #30
                      Originally posted by loopypalm
                      @Per Hansson
                      the GPU
                      Ouch.
                      While ChaosLegionnaire is correct that those GeForce GTX 4x0 and 5x0 cards run very hot, you should still try to keep yours as cool as possible. Try using a program like RivaTuner or MSI Afterburner to turn up the GPU's fans, especially when playing games (might want to put the fan at 100% on very demanding games).
                      Yes, probably. When polymer caps go bad, they typically go just like you saw. So no need to worry now that you replaced that cap. If there are anymore to go, they will go, and there's nothing you can do about it. Just use it and see. Most likely, the rest of the caps will be fine.
                      • loopypalm
                        • May 2017
                        • 4
                        • morocco
                        #31
                        Ouch.
                        While ChaosLegionnaire is correct ...
                        Yes, probably...
                        i did a hardware mod (i add another fan ^w^ !)
                        it get 30C when watching videos and 50C when playing games
                        i think that's okey (i will try the software you listed)
                        thank you for everything !
                          EVGA e-GeForce 7600 GS AGP 256MD2 [256-A8-N542-T2] with bad caps - fixed
                          by momaka
                          I did it again – I had to fulfill my inner desire to fix yet another old piece of hardware. This one is actually kind of worthwhile, too – it’s an EVGA e-GeForce 7600 GS AGP video card, model P/N: 256-A8-N542-T2. With the popularity of “retro” PCs from the Win9x to XP era going up, and the diminishing supply of decent AGP cards, it is expected their prices will go up. Or is it? I bought the this video card rather on the cheap side (~$9 USD shipped to my door), because the eBay seller listed it for parts or repair (and correctly noted the bad capacitors.)
                          So, here is the...
                          06-06-2020, 04:39 PM
                          by momaka
                          03-12-2025, 03:42 PM
                        • eryjus
                          by eryjus
                          05-10-2023, 11:21 AM
                        • Paxman_Swede
                          by Paxman_Swede
                          Hello!
                          01-14-2025, 09:51 AM
                        • captain150
                          by captain150
                          03-16-2025, 07:34 PM
