MSI 815E Pro (MS-6337) Socket 370 - Bad caps
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Yet another MSI with bad caps. The originals were GLUXON. I replaced (qty of 8 ) 1500uF 10v and (qty of 11) 1000uF 6.3v caps. A guy send a big box full of these to recap for him, removed from workstations on a network.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    No new P4s for the workforce now, they will be stuck on 815e for years now after recapping.
    You see the very little caps in the second photograph which are to the left of the battery. Larger versions of these caps i see on video cards. Is there any special thing about these caps or just cosmetic - can we expect the larger ones to vent in the usual way.
    Can we see the recapping please?
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16958
      Nope, no P4's and upgrades for those office employees... The P3 lives on!!
      Here ya go:
      Team : 49813
      Join in!!
      Team Stats
        by momaka
        03-12-2025, 03:42 PM
      • eryjus
        by eryjus
        05-10-2023, 11:21 AM
      • Paxman_Swede
        by Paxman_Swede
        Hello!
        01-14-2025, 09:51 AM
      • mrzmaster
        QDI socket 370 motherboard Bad caps or dirt?
        by mrzmaster
        Hey all, I am in the process of putting together a "vintage" Pentium III system and picked up a QDI socket 370 motherboard.
        The individual I bought it from said it's in excellent working condition, but since I'm still in the process of collecting some necessary parts, I haven't had a chance to try to get it to post yet.
        I noticed that some of the caps around the socket appear to be either leaking or maybe just dirty (they're near where the heatsink/fan is) but I can't tell for certain. The caps are not bulging whatsoever and are as flat as could possibly...
        09-22-2021, 09:34 PM
      • captain150
        by captain150
        03-16-2025, 07:34 PM
