This isn't a very common motherboard. The board is for athlon MP processors and uses the original MPX chipset. It was extremely stable for me for over a year, but I recently began having "machine exception fault" errors all the time. My temps look fine so I decided to take a look at my caps, sure enough, 13 of them are leaking, several pretty bad. My Vcore is 1.75v (hard modded on the chips) but my vcore bounces between 1.7v and 1.76v. Looks like she's gonna be going in for repairs since this board still sells for $180 new. Currently running 2x athlon 2500XP's modded to run in dual, 16.5x multiplier, and 1.75vcore.
Gigabyte GA-7DPXDW
Welcome to the boards.
If you need it recapped, feel free to email or PM me.
TC<--- Badcaps.net Founder
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team Stats -
No prob. I've sent the info to you in a PM.<--- Badcaps.net Founder
Team : 49813
Join in!!
Team StatsComment
Re: Gigabyte GA-7DPXDW
funny about the timing.
i was pm ing you on 2cpu about the repair of this board and got 5 more emails with the same problem with the same board.
i now have 7 of these inbound for service.
seems these boards are all dieing at once.
Originally posted by DracoDanThis isn't a very common motherboard. The board is for athlon MP processors and uses the original MPX chipset. It was extremely stable for me for over a year, but I recently began having "machine exception fault" errors all the time. My temps look fine so I decided to take a look at my caps, sure enough, 13 of them are leaking, several pretty bad. My Vcore is 1.75v (hard modded on the chips) but my vcore bounces between 1.7v and 1.76v. Looks like she's gonna be going in for repairs since this board still sells for $180 new. Currently running 2x athlon 2500XP's modded to run in dual, 16.5x multiplier, and 1.75vcore.Comment
I've been talking with topcat here about my issues (thanks for introducing me to these boards). It looks like my best bet is going to be to sell him the board. I made him a respectable offer and he accepted. Now I just have to find a replacement board and cpus before I sell. Im thinking about the Tyan tiger K8W (looks like it has high quality caps
). And getting a single opteron 244. Its going to be hard letting my dual 2.2ghz setup go, its been amazing up until the last few days. BTW, is anyone interested in some nice barton 2500+s @ 2.2ghz/1.75v/MP?
i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
VCCIO voltage ok
VCCSA Voltage OK
VCCPLL Voltage OK
Ram Voltage ok
RamVTT OK
VPP 2.5 OK
But No Core Voltage
and i want to this vrm ic datasheet or pinout (ISL69269)
anyone have this ic pinout voltages?... -
by DynaxSCHi,
I discovered a strange behaviour of GIGABYTE GA-H110M-S2 board.
General test conditions:
- Tested with Core i5 6500 and Core I7 6700K - no difference
- Default BIOS settings, but tried also altering several memory setting - does not change anything
What is wrong:
With BIOS F1 and F2 the board normally POST's and boots to Windows 11 with 2 x Patriot Viper Steel PVS416G440C9K RAM (4400MHZ, Samsung B-Die chips)
When BIOS upgraded to anything above F2 (ie. F20-F27b) the board POST stucks after 3 Debug Codes on Code C2... -
by barry101Hi, Would appreciate some help.
I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
Get charger light but no fan spin or chime. No liquid damage.
Found PPBUS and VCORE both shorted to ground. Other rails were ok.
Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my... -
Thermal pad thickness for various laptop GPU / Graphics Cards
ASUS Dual RTX 2070 OC 8GB
ASUS ROG STRIX RTX 3080 OC
ASUS ROG STRIX RTX 3090
ASUS TUF Gaming RTX 3080 OC Edition
ASUS TUF GTX 1660 S-O6G GAMING
EVGA RTX 3060 Ti XC GAMING 8GB
EVGA RTX 3060 XC GAMING 12GB GDDR6
EVGA RTX 3080 FTW3 ULTRA GAMING
EVGA RTX 3080 TI FTW3 ULTRA GAMING
EVGA RTX 3090 XC3 ULTRA GAMING 24GB
Gainward RTX 2080 Phoenix GS Specs
Gainward RTX 3070 Phoenix 8GB
Gainward RTX 3080 Ti Phoenix
GIGABYTE AORUS RTX 3080 MASTER 10G
Channel: Schematics and Boardviews
by ktmmotocrossI have this Gigabyte GTX 1070 that have no Vcore, but other voltages are ok
any hint? i add measurements... - Loading...
