MSI 694D Pro ver 1 (MS-6321)
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16956
    I've seen and rebuilt a bunch of these over the last year or so, and had a cap kit for a long time as well. I recently got a good buy on one, and decided it might be helpful to post the info in here for reference. The bad caps are made by Teapo and Teyah, so no surprise that they're bad.
    Here's what needs to be replaced:
    6 - 2200uF 6.3v
    5 - 1500uF 10v
    7 - 1000uF 6.3
    3 - 1000uF 6.3v low profile
    There are 21 caps that need to be replaced to successfully rebuild this board. I made a substitution on this board, replacing the 2700uF caps with 2200uF caps. This caused no problems whatsoever, since 2200uF is within the 20% tolerance of 2700uF. The rest I replaced with the original values. Also, replace ALL the 1000uF caps throughout the entire board! They're all crap even if they're not bloated or vented!
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    i used 3300@10 in all the 694's i have done
    1 i got them cheap
    2 it only keeps the vcore a bit cleaner.
    did you notice what folks are paying on ebay for these with obvious bad caps showing in the pics?
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16956
      I never did look them up on Ebay. What were they running?
      I would have used 3300uF caps, but the only ones I have are 12.5mm, and would not have fit well. I usually don't reduce capacitance if I have a choice, and would have preferred to go up...
      Team : 49813
      Join in!!
      Team Stats
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        i have 12.5mm too
        they dont fit as nice as a 10mm but i am going to really hotrod these and other than me or some baby boas nobody will see it.
        • RukyCon
          ZUMAX Technology (Leadman Power) ZU400W (X1), Modifications & Life Test
          by RukyCon
          Hello Again, so i'm bringing back this Zumax PSU from the gutless thread and going to be doing some modifications, and also putting it into a PC i'm going to throw together out of spare parts to see how long it lasts.
          So the first thing i did was fill in the missing filtering, by replacing the cheap common mode choke with a real one and adding a 470nf X2 capacitor in the open capacitor spot, i then replaced the fake Y-class capacitors with real ones, i also swapped out the mismatched primary caps with a pair of Aishi WK 470uf 200v caps, both of which test around 520uf. I also swapped...
          04-15-2022, 11:20 PM
        • pavithra_uk
          recap help AcBel PSU
          by pavithra_uk
          I found used PSU AcBel PC6001 ~250W from IBM thinkcenter Core2Duo system. Almost every output rail caps were bulged except 12V rail single cap. caps were Ltec
          12V - 1200uF 16V
          5V - 1000uF 10V before coil 1000uF 10V after coil
          3.3V - 1000uF 10V before coil 1000uF 10V after coil
          5Vsb - 1000uF 10V before coil, 470uF 16V after coil
          Since I have no access to buying new branded caps, I'm going to replace caps with used caps I pulled from dead PSUs and Motherboards.
          I need cap experts ideas about it.
          This PSU will...
          06-27-2021, 02:02 AM
        • cloppy007
          [MSI KT3 Ultra ARU] Advice on capacitor choice
          by cloppy007
          I've found out that the all the Nichicon HM(M) caps on this board are faulty and need replacement. However, I didn't plan in advance and I don't have good replacement caps.
          The original values are 2200uF, 6.3V, 5mm pitch. According to the datasheet, the rated impedance should be around 13-18 uOhms.
          There are 8 of them, 3 to the left of the CPU socket and 5 on the bottom, very close to the northbridge. They are all connected, according to my multimeter.
          I think I recall hearing that I don't have to use the same capacitance for in series...
          08-21-2023, 03:18 PM
        • frannyjunk
          Vizio M60-C3 Replacing 1000uF 16V with 1000uF 35V capacitors?
          by frannyjunk
          Hi, my Vizio M60-C3 does not power on. No lights whatsoever. Upon opening up the TV, the power supply board has 4 bulging capacitors. Each is 1000uF 16V. I have read that one can use capacitors of the same uF and higher voltage rating, but is 1000uF 35V capacitor too high of a voltage rating? My local shop only has these higher voltage capacitors so would rather just buy the 35V variety if it is OK to use them.
          Any thoughts if OK to use these higher voltage capacitors?
          11-04-2021, 05:59 PM
        • Superbee68104
          Looking for a Cap 1000uf 120v 46mmx18mm or something close
          by Superbee68104
          1000uf 120v 46mmx18mm or something close, Thanks
          01-21-2024, 01:05 PM
