ive just got a 1gb pc 3200 400mhz ddr ram-184pin ram card ive put it in the pc at the side of my 512/ddr400 and its not working do i have to do anything else to make it work please help
ms-6788 848p neo v ram prob
Re: ms-6788 848p neo v ram prob
Welcome Ian,Originally posted by ian072ive just got a 1gb pc 3200 400mhz ddr ram-184pin ram card ive put it in the pc at the side of my 512/ddr400 and its not working do i have to do anything else to make it work please help
Do both sticks work correctly and pass testing with, say, Memtest86+ if used individually? -
Are these AMD64? I believe that early ODMCs on dual-channel Athlon-64/Opteron CPUs sometimes had difficulties when two unmatched DDR dimms of different capacities and/or timings were paired. The Rev E CPUs are supposed to have solved most of these issues (at least, I was able to use DDR400 paired with DDR 333 with my Rev E Athlon-64, but it dropped back to 333 on both DIMMs).Comment
wow hold your horses guys me novice lol
ive tried it with my 512ddr in both slots and also on it own when its in on its own the pc doesnt even boot up
as far as testing it thats all ive done i dont know if theres any more tests
i had a look in bios but dont know if i should change anything
ddr power volt-2.60v anymore help please
thanks ianComment
The fact that the machine will not boot up with that single memory stick installed suggests either a fault with the stick itself, or a compatibility issue of some kind.Originally posted by ian072ive tried it with my 512ddr in both slots and also on it own when its in on its own the pc doesnt even boot up
When you say it doesn't boot - do you mean that the screen simply stays dark/powered off, and the motherboard gives you a memory error code (whether beeps or C1 port 80)? Or something else?
What you could also try to do would be to clear the CMOS NVRAM, by removing the battery for a minute or so, or moving the appropriate jumper to the "clear cmos" position.Comment
ive put the 1gb ram in the first slot and 512 in second had a look in bios
advanced chipset features
dram timing settings
cas#latency 3 clocks
ras#precharge 3 clocks
ras# to cas# delay 3 clocks
precharge delay 8 clocks
burst length 8
agp aperture size 64mb
freqency voltage control
dynamic overclocking disabled
performance mode normal
cpu ratio selection locked
dram frequency auto
anyone know what to change to try make it work
screen just stays black to last questionComment
http://www.memoryx.net/miin84nemmom.html this is my motherboard and 1gb pc3200 ddr400 non ecc 2.5v it should be compatable neo v 848pComment
So hang on, you're saying that with both sticks installed the machine does in fact boot up, or at least POST...
Then what's the problem, as in, where does it actually go wrong? Does it only successfully POST sometimes, or hang while the OS is loading, or give you a particular blue screen?
If you can get so far as to boot from a CD, try running Memtest86+, last version is 1.65. You can download it from http://www.memtest.orgComment
ive got a 512 in my pc that works fine i got pc booster that tells me 512ram i wanted to upgrade so i looked for a 1gb one compatable found this one got it put it in still said 512mb swoped 512 out of slot one with 1gb in slot 2 still no joy put 1gb in slot 1 on its own did not boot black screen no beeps
put 1gb in and looked in bios
burst length 8
dram frequency auto
read about dram timing settings but dont know what to change in bios to tryComment
Nobody else seems to be answering so I'll try:Originally posted by ian0721gb in slot 2 still no joy put 1gb in slot 1 on its own did not boot black screen no beeps put 1gb in and looked in bios
What does the part that you wrote, that I highlighted (in bold) mean? I really want to help you here - it's just that I don't get what you're trying to say.
If, with the 1G stick it does *not*, in either slot, POST - but leaves you with a black screen and no beeps, then there is *no way* you can access the bios/cmos setup screen, right?
If, additionally, you cannot POST with that one 1G DIMM, when your DRAM settings are set to the default 3-3-3-8, then generally, there is a problem. Either a compatibility issue between MB and DIMM, or a fault in the DIMM itself.
I suggest you try this:
1. Install your known good stick of RAM (512M) and nothing else. Then, in a safe manner, flash your MB's BIOS to the latest release from MSI. Sometimes BIOS updates resolve mysterious "hardware" issues.
2. Once that's done, power down, and clear your CMOS (nvRAM).
3. Then remove the 512M DIMM, and install the 1G DIMM first in one slot - and try to start up the machine. Failing this, try the 1G DIMM in the other slot. I'm assuming your MB has two slots, right?
4. If the system simply won't post, and acts dead with the 1G DIMM in either slot, then either:
a) The DIMM is, for some reason, not supported by your motherboard.
b) The DIMM is defective.
Let us know how it works out...
PS. Linuxguru: no, it's a socket 478 as far as I can see.Last edited by tiresias; 08-17-2006, 06:21 PM.Comment
Probably the safest option - occasionally you just get a malfunctioning stick, even with the best brands.Originally posted by ian072i carnt for the life of me get memtest to work downloaded it ok but carnt get it to run ive had enough of this now sending it backComment
by misha97123Hi, such a problem, the laptop after an unsuccessful firmware update, the dump was dirty, I flashed the dump (from the offsite), the laptop turns on and the battery charges everything seems OK, but if the power supply and battery are connected at once, then the touchpad freezes and the OS loads long time, but if you work only from the battery or only from the power supply then everything is fine and fast, and there is also a problem that when you disconnect rtc and turn off all power, the asus boards should have an auto turn on, but it does not... also, if you turn on the laptop from the button...08-09-2023, 04:00 AM
The Intel Core i7-900 desktop processor Extreme Edition series and Intel Core i7-900 desktop processor series are intended for high performance high-end desktop, Uni-processor (UP) server, and workstation systems. Several architectural and microarchitectural enhancements have been added to this processor including four processor cores in the processor package and increased shared cache.
The Intel Core i7-900 desktop processor Extreme Edition series and Intel Core i7-900 desktop processor series are the first desktop multi-core processor to implement key new technologies:
Channel: Common Parts Library - Datasheets
10-23-2024, 02:56 AM -
by gugutmHello everyone,
I'm new to the forum,sorry english is not my first language too, i got a basic plus knowledge, but now i am in this situation where i need some help , i spend good few days reading forums , here and outside , to help my problem solve, with no luck
long story short, i bought macbook pro a1989 820-00850, clean no water damage which was stuck on 5v 0.200/300a i read a lot of forums what that could be , it indicated to faulty corrupted t2 rom
of course before jumping to conclusion and connected to DFU , i believe i done basic checks... - Loading...
