Well i got this motherboard with cpu from a friend of mine,
Everything was workin "pretty" ok except the capacitors closest to
the atx connector (the three green) they got hot as hell :P
then i looked little closer to the board found some leaky ones
old manufacturer on the caps are "Jackcon" and i replaced them with Jamicon TMR series the only bad thing is the old where 8mm and the new where 10mm type but i did not care how it looks only that it works
Pictures:
before:
after:
There is also pictures with higher res here:
http://212.181.198.223/img/badcaps/
I will also (after i discover it) remove the motherboard and desolder
one pin of each ata connector stupied pin stopped me from using the better
ata/100 cables you can see it in my high res images in the link above
(The black 40 pin is the standard ata interface the Green belongs to the raid
circuit the green is missing pin nr 20 but not the black really stupied...)
And another thing:
Is it any one here who knows if there is any one selling 8mm caps in europe ??
Also need 2200uF 16V / 3300uF 10V in 10mm version for an psu repair
if any one know where to buy drop me a pm...
//Hagis
Pictures:
before:
after:
And another thing:
//Hagis
