GigaByte K8NSC-939
  • algomez
    • Jan 2011
    • 17
    GigaByte K8NSC-939
    This is my brother's computer MB. The computer boots fine but then shuts down randomly and starts going into a rebooting cycle.
    I found 5 bulging caps evident in the photo below.
    I'm going to change those 5 caps and see if that fixes it.
    I'll let you know.
  • mockingbird
    • Dec 2008
    • 5484
    Re: GigaByte K8NSC-939
    That's odd... When was this board manufactured? What's the datecode on those bulged Nichicon HM?
    • c_hegge
      • Sep 2009
      • 5219
      Don't just replace the 5 bulgers. Replace them all. The others are probably not far off failing, or may have already failed without visibly showing it. Also make sure to use good ultra-low ESR caps, not just any 1000uF caps. https://www.badcaps.net/store/produc...roducts_id=131 will be fine.
      • algomez
        • Jan 2011
        • 17
        I take it this is the code: A0451
        I looked for the manufacturer date but the font is so small I need a magnifying glass. I'd say it's about 5 to 6 yrs old though running a P4 I believe.
        • algomez
          • Jan 2011
          • 17
          Yes, I know that's the way I'll go. I'm going to make a list of all the values etc..
          I also have three shuttles in my garage with bad caps. I'll make a different post when I get to those. This site really opened my eyes on why comps go bad.
          • c_hegge
            • Sep 2009
            • 5219
            A0451 is indeed the date code. That means year 2004, week 51, which means that they are defective. The problem wasn't fixed until the next year.
            • mockingbird
              • Dec 2008
              • 5484
              It should have been fixed by 2004 week 51 but apparently it wasn't.
              • c_hegge
                • Sep 2009
                • 5219
                No, it was fixed during 2005. Some of the early 2005 caps may also be suspect.
                • algomez
                  • Jan 2011
                  • 17
                  A quick update, I replaced the 5 bulging caps (6.3v 1000uf HMs) with exact replacements and the MB has not shutdown once after staying on a full day. I know I should probably replace all the caps but I may just ride this out as I really want to get to my shuttles
                  I am going to do a fresh windows install as well and leave it at that for now.
                  Thanks-
                  • ChaosLegionnaire
                    HC Overclocker
                    • Jul 2012
                    • 3261
                    • Singapore
                    Originally posted by algomez
                    ... running a P4 I believe.
                    the k8nsc939 is an amd athlon 64 socket 939 motherboard NOT pentium 4.
                    also, i'd like to point out that its a nvidia chipset mobo which *might* have solder balling problems on the chipset. not sure if nvidia nforce3 250gb chipsets are on the list of bad nvidia chipsets but if it is, then u might have repaired it now but it might eventually fail again down the road. just fyi~ lol
                    • c_hegge
                      • Sep 2009
                      • 5219
                      This board predates the problems. that only affected Socket AM2 boards.
                      • DynaxSC
                        GIGABYTE GA-H110M-S2 - Stuck at Debug Code C2 - don't like Patriot Viper Steel RAM but works with G.SKILL
                        by DynaxSC
                        I discovered a strange behaviour of GIGABYTE GA-H110M-S2 board.
                        General test conditions:
                        - Tested with Core i5 6500 and Core I7 6700K - no difference
                        - Default BIOS settings, but tried also altering several memory setting - does not change anything
                        What is wrong:
                        With BIOS F1 and F2 the board normally POST's and boots to Windows 11 with 2 x Patriot Viper Steel PVS416G440C9K RAM (4400MHZ, Samsung B-Die chips)
                        When BIOS upgraded to anything above F2 (ie. F20-F27b) the board POST stucks after 3 Debug Codes on Code C2
                        03-21-2025, 06:23 PM
                        Thermal pad thickness for various laptop GPU / Graphics Cards
                        ASUS Dual RTX 2070 OC 8GB
                        ASUS ROG STRIX RTX 3080 OC
                        ASUS ROG STRIX RTX 3090
                        ASUS TUF Gaming RTX 3080 OC Edition
                        ASUS TUF GTX 1660 S-O6G GAMING
                        EVGA RTX 3060 Ti XC GAMING 8GB
                        EVGA RTX 3060 XC GAMING 12GB GDDR6
                        EVGA RTX 3080 FTW3 ULTRA GAMING
                        EVGA RTX 3080 TI FTW3 ULTRA GAMING
                        EVGA RTX 3090 XC3 ULTRA GAMING 24GB
                        Gainward RTX 2080 Phoenix GS Specs
                        Gainward RTX 3070 Phoenix 8GB
                        Gainward RTX 3080 Ti Phoenix
                        GIGABYTE AORUS RTX 3080 MASTER 10G
                        02-09-2024, 08:08 AM
                        A Dead/DOA Gigabyte GP-P450b 450W ATX PSU
                        by momaka
                        More eBay specials: this time a Gigabyte GP-P450b 450W ATX PSU for $8 with free S&H. Listed “For part/not working”, as usual. Showed up in a beat up EVGA box without any padding… but that's understandable given the total price. PSU made it out fine without damage. It's a non-modular (yay!), pretty modern-day looking PSU with a black paint and all black cables (meh, not my favorite, but figure it's good to keep a few of these in case I do need one for a more modern PC build, just so my old gray boxes don't look too odd in there.)
                        And a shot of the label:...
                        01-26-2022, 03:26 AM
                      • TR103
                        by TR103
                        - it keeps rebooting
                        01-22-2025, 04:12 PM
                        Gigabyte G series G5 KF-5 Notebook Specification for Upgrade or Repair
                        This specification for the Gigabyte G series G5 KF-5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the G5 KF-5 boardview and G5 KF-5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Gigabyte...
                        09-07-2024, 07:19 AM
