So I got this Gigabyte s478 for free, too lazy atm to check what model it is, and when I tried to start it wouldn't boot at all so I used the hairdryer trick to heat up the capacitors to see if it'll start (all OST and a few KZG's none bulging) and it did boot but only to the point of initializing USB devices. I'm thinking of recapping the whole mobo with salvaged caps from other mobos but don't know if it's worth the effort. Could this problem be caused by the OST caps that are obviously failing or could it be the the USB controller IC and will removing it allow the motherboard to boot normally? Also when I plug in the 20pin PSU connector or the power cord to the PSU the fans on the mobo briefly start turning and after about a second they stop. The mobo has a VIA chipset I think... I'll have to check what mobo it is tomorrow, getting late here. Pic's coming up in next post.
Gigabyte s478 mobo hangs on initializing USB devices during post
by HexelHello!
I need help identifying part name of IC in QFN16 packadge under SSD, near audio jack and 1206 capacitors (marked on photo). Unfortunatelly there is no refdes of that part so that is only info I can provide. I took boardview here on forum for revosion 2.0, but it doesn`t have this part at all, not just moved. Maybe someone have relevant schematic or BV.
Notebook was poured with coffee and someone already tried to fix it but as usual made jusy worse. I`ve restored all mobo defects and now it powers up, starts OS booting but hangs on OS logo. I believe missing part may... -
by DynaxSCHi,
I discovered a strange behaviour of GIGABYTE GA-H110M-S2 board.
General test conditions:
- Tested with Core i5 6500 and Core I7 6700K - no difference
- Default BIOS settings, but tried also altering several memory setting - does not change anything
What is wrong:
With BIOS F1 and F2 the board normally POST's and boots to Windows 11 with 2 x Patriot Viper Steel PVS416G440C9K RAM (4400MHZ, Samsung B-Die chips)
When BIOS upgraded to anything above F2 (ie. F20-F27b) the board POST stucks after 3 Debug Codes on Code C2... -
Thermal pad thickness for various laptop GPU / Graphics Cards
ASUS Dual RTX 2070 OC 8GB
ASUS ROG STRIX RTX 3080 OC
ASUS ROG STRIX RTX 3090
ASUS TUF Gaming RTX 3080 OC Edition
ASUS TUF GTX 1660 S-O6G GAMING
EVGA RTX 3060 Ti XC GAMING 8GB
EVGA RTX 3060 XC GAMING 12GB GDDR6
EVGA RTX 3080 FTW3 ULTRA GAMING
EVGA RTX 3080 TI FTW3 ULTRA GAMING
EVGA RTX 3090 XC3 ULTRA GAMING 24GB
Gainward RTX 2080 Phoenix GS Specs
Gainward RTX 3070 Phoenix 8GB
Gainward RTX 3080 Ti Phoenix
GIGABYTE AORUS RTX 3080 MASTER 10G
Channel: Schematics and Boardviews
by momakaMore eBay specials: this time a Gigabyte GP-P450b 450W ATX PSU for $8 with free S&H. Listed “For part/not working”, as usual. Showed up in a beat up EVGA box without any padding… but that's understandable given the total price. PSU made it out fine without damage. It's a non-modular (yay!), pretty modern-day looking PSU with a black paint and all black cables (meh, not my favorite, but figure it's good to keep a few of these in case I do need one for a more modern PC build, just so my old gray boxes don't look too odd in there.)
And a shot of the label:... -
Hi Everyone,I need help with this strange Gigabyte laptop,it turns on with black screen and after 30sec fans on the Max for few seconds and it shuts down,I think the bios is bricked,They say it is Clevo under the hood,there is nowhere on motherboard what is the model which is strange,i will write S/N and P/N from the motherboard,thats only what is writen there and upload old bios,if anyone can help,Thanks!
Gigabyte A5 X1
From motherboard:
S/N: 1TNH55ER1350895
P/N: 6-77-NH55ERQY-D02-2CGB
On sticker from the back of the laptop:
S/N: SN21351J000657...-
Channel: BIOS Requests ONLY!
- Loading...
