GA-X58-USB3 Capacitor Help
  • mllrkllr88
    • May 2012
    • 3
    Hi guys,
    I am a new member, but have been lurking for a bit. I have a motherboard that has a missing cap, and I need to know what to buy. The problem is that I cant decipher the capacitor values. The cap I need is the same as other ones in the area, yes, I have confirmed this. It is labeled "E07E" then "560" then 6.3v. Anyone know what to make of it?
    Thanks,
    Dave
  • mariushm
    • May 2011
    • 3799
    Re: GA-X58-USB3 Capacitor Help
    It's a 560uF , 6.3v capacitor. The E07E doesn't tell anything, it varies from manufacturer to manufacturer and it's a code .. sometimes it's manufacturing date (week and year).
    Here's a picture of the board, point out the one missing on the board:
    http://www.nix.ru/autocatalog/mother...2245_draft.jpg
    Anyway, these will work (90% sure) :
    http://search.digikey.com/us/en/prod...227-ND/1826691
    http://search.digikey.com/us/en/prod...0-1-ND/2347908
    • mllrkllr88
      • May 2012
      • 3
      Wow, surprising response time.
      Here is the missing cap.
      • c_hegge
        • Sep 2009
        • 5219
        Knowing Gigabyte, it's probably Chemi-con PSE series. use http://search.digikey.com/us/en/prod...255-ND/1948052 to replace it.
        EDIT: I can confirm from another board that the cap in that position is indeed a PSE, like the one in that link.
        • mllrkllr88
          • May 2012
          • 3
          I am impressed with this forum, lost of active people!! If you guys wanted to double check that 560uF cap, that would be awesome. I really dont care what it looks like, but if that Chemi-con PSE is the same cap used, then I would definitely use that one.
          +1 to both of you who responded.
          • c_hegge
            • Sep 2009
            • 5219
            I did. I had a similar board right next to me. The cap in that corner was a 560uF Chemi-Con PSE, which is exactly what I linked to, so it should work fine.
            • doyll
              • Mar 2015
              @ mariushm
              Sorry for the necro, but wanted to thank you for posting exactly what the cap is. I have been searching for almost two months trying to find out exactly what it's specs were with no joy.
              • Divien
                • Jul 2015
                • Russian Federation
                Originally posted by doyll
                @ mariushm
                Hi! The same problem! Repaired motherboard successfully? What capacitor used? Everything works fine? Please answer
                • cyjun1990
                  • Jan 2016
                  • 16
                  • Philippines
                  Repaired IT? please reply
                  • MORETTIGIAN
                    Capacitor detached from PCB – RTX 2070 Super Founders Edition
                    by MORETTIGIAN
                    Title:
                    Description:
                    During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                    I did not notice it detaching, so I am unsure of its original location on the PCB.
                    Procedure performed:
                    - Removed backplate
                    - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                    - Reapplied thermal compound
                    - Reassembled card
                    Observed behavior after reassembly:
                    - GPU powers on and operates normally under...
                    09-18-2025, 12:14 PM
                  • benberry24
                    surface go 2 missing capacitor, Motherboard# DA0Z93MBAE0
                    by benberry24
                    I have surface go 2 that a capacitor was nocked off. Can anyone tell me the value of the missing capacitor or if it's needed.
                    Motherboard# DA0Z93MBAE0...
                    09-12-2025, 10:16 AM
                  • krob80
                    PS5 Edm-010 No Power - Help identifying missing capacitor
                    by krob80
                    Hey everyone. I recently acquired a PS5 that is not turning on (no beep/power). PSU is good and there is no shorting on the 12V rail.
                    It came with a Gen3 SSD installed so I feel that things went down hill for the previous owner when it was installed. F7003 was blown but there was nothing shorting to ground. I replaced the fuse but still no power (new fuse is still good for now).
                    When connecting it to a bench power supply, it only pulls 10 mA (doesn't spike when first connected).
                    I noticed that there are a couple capacitors missing from the Vcore power regulator (pictures attached)....
                    05-15-2025, 04:24 PM
                  • Prolog
                    RTX 3080 FE Identifying capacitor
                    by Prolog
                    Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                    I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                    I hope these photos make it clear which component I am referring to:
                    (yes, the soldering is a bit botched from removing the blown one, I know)
                    I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                    12-01-2024, 08:27 PM
                  • fab13
                    Capacitor missing on GTX 1050 TI 4GT OC - Need help
                    by fab13
                    Hello everyone and happy to post a message, I have an MSI GTX 1050 ti 4gt oc and at any time the card gives me a black screen and then nothing.
                    Even when trying to install windows for example at startup, the card started to make a black screen.
                    I have not yet tried to take measurements but I have observed a missing capacitor which is impossible to find on the boarview and seems nonexistent for this one or diagram.
                    In addition, my thermal camera shows an overheating of 40 degrees at this location.
                    I show you a photo named (InkedGTX 1050 GOOD_LI)...
                    12-30-2021, 04:27 PM
